Finishing trim - 3 sides or all 4?
ChuckT
>We have about 1000 bd ft of Red Oak lumber that we are staining and finishing with Poly for our carpeter to install (I know - I should be doing that myself - but I jsut don't have time). Anyway - this lumber was kiln dried and has been sitting in my garage since last winter. The carpenter said that we could just finish 3 sides to speed things up. However, I am concerned that this might lead to warping due to uneven moisture absorption and movement. Should we in fact at least poly the back sides as well?
Thanks for any advice anyone here can offer.
ChuckT
Re: Finishing trim - 3 sides or all 4?
1 for all all 4 for 1
Dustmaker Mike
>I would at least put one coat on the last side. It won't take long and it will make you sleep better.
depends on how big
Bill Tindall, E.TN
>I only did 3 sides on my trim but it is at most 3 1/2" wide. By comparison, you don't finish floor boards 4S.
Re: depends on how big
Glenn Madsen in the SF Bay Area
>but floor boards are nailed every six inches through the tongue, and tongue and grooved to fit the next board. And some folks squirt adhesive under them as well.
I'd thin the finish, and wipe it on. One coat for the back, and as many as the fronts needs to look right. Dries faster, less ooze that Red Oak is prone to, and cheaper application tools...
Jason Roehl in Lafayette, IN
I have never.
>In my years of painting (and occasionally wearing a carpenter's hat), I have never finished the back side of trim, seen anyone else finish the back side of trim, or pulled trim that had the back side finished--from any era of house dating back to the early 1900's.
Exterior trim is another story.
Jason
Fred Davis
>If we are talking about window and door casing, base and flooring , then the back side is always relieved. Not doing so practically garantees cupping of the wood.
All commercial trim and flooring is done that way for a reason. This can be done with a moulder and knife made for that purpose, or more slowly on the tablesaw with a dado set up with 1/4" spacers between the chippers and outside blades.
FredD
Fred Davis
>also jamb stock and window stool material.
>I did my previous house in red oak, milled 2.5" and 3.5", without back relief. I did finish all the back sides so I can't say what would happen if I didn't. It really didn't take much extra time - I laid the pieces on sawhorse supports and slopped poly on the back side first and let it dry against the supports while taking more care with the exposed sides.
