>A while ago we had some water in our partially finished basement. I've since cut out the bottom 16" of drywall where necessary and now need to replace it. Do I somehow need to toenail 2x4 pieces between the wall studs where the new and old drywall will meet, or is it sufficient to just put the 16" strips up and tape the joint between old and new? I'm guessing I already know the answer, but am holding out some hope that I'm wrong:)
>There should be no need to put the blocking on the horizontal joints at your 16" level. Drywall is normally put up in two four foot high sections and there is no "backers" behind that horizontal joint. That joint is generally the tapered edges of the new board and is easier to tape and blend in. Your full thickness butt joints will just take more work to feather the joint out so you do not have a defined hump in the finished wall.
This all assumes your studs spacing and drywall thickness are correct and you cut out enough drywall it is not buckled or swollen from moisture.
Not a fun job at that height as you are on your knees too long!
>Tom, I see no need to put any extra backing in as long as the existing sheetrock is still flat and not bowed between the 16" center studs. I would put the new pieces in with the raw cut edges together and not a beveled manufactured edge against the cut edge, George
Agree with the other posters and you might try squirting a bead of construction adhesive along the wall stud to make sure the piece of wallboard doesn't come pop loose in the future. This works well on those studs where you are using only 3/4 inch of the stud to fast the wallboard edge.
What I do when patching a hole or section of drywall where support would be helpful, learned untold years ago watching an expert: cut a piece of wood, perhaps 3/4" thick, a couple inches wide, and long enough to span the joint or most of it. No need to fasten it to the studs. Hold the wood in place behind the existing drywall and secure with drywall screws. Position the patch and fasten it with screws.
This method may not be necessary if both your original wall and patch pieces are rigid and flat, but it is helpful for thinner sheets, where there may be some irregularity, and especially for patching a hole.
