Painting a finished table top and chairs
Rick Van Schoick
>The table set located at the link below is a mess. I was planning on replacing the top, which I think is MDF with a thin veneer, with real wood, but discovered midway that my table saw doesn't have the rip capacity to get the job done, so now I'm thinking of painting it. It has the veneer and a thin finish on top. I'm assuming that I just need to sand it smooth, not necessarily to bare MDF, just to level and rough up the surface. After that, what type of paint would be best for a table top and should I then cover that up with a hard polyurethane finish to protect it and add durability? Your thoughts are appreciated. Thanks. Rick
Re: Painting a finished table top and chairs
Rick Van Schoick
>Sorry, here's the link:
www.rickswoodshopcreations.com/miscellaneous/evergreen.htm
>If there's any de-lamination, re-glue it. Wipe it down with naptha. Fill any dings/cracks with Durhams Rock Hard putty; it can be mixed with white glue for a super sticky hard filler. Base coat with flat latex wall paint in your favorite color. Top coat with water borne poly floor finish. It has worked for me.
Clint
Contrary Opinion
David Yoho
>Rick, if I were doing this table top, I'd leave paint as the last resort. The pictures I saw didn't indicate enough surface damage to not take a shot at refinishing what's there.
Since you say the finish is thin, why not strip it with a stripper? I like BIX brand semi-paste available here from HD. The trick when stripping a veneered surface is to not keep it wet any longer than necessary. If the finish is thin, the stripper shouldn't take long to do its work. Scrape or scrub it off, wipe the remaining residue off with a big sponge, rinsing after each pass. When it's dry, you'll have to sand it. I'd probably do this by hand so as to be more careful about not cutting through the veneer. Sometimes these veneers are thicker than normal and there's room for sanding. After this, apply a fresh finish and see how it looks.
Should something go wrong during the stripping or sanding stage, you could always fall back on your plan to paint it.
David
Steve Schoene
>As far as preparation, fix loose veneer, scuff sand to remove all gloss, fill any dings and scratches, and then use a couple of coats of BIN shellac type primer. Sand the primer critically, looking for any defects missed on the first go around.
An oil based enamel would give the best most durable finish. It wouldn't need a varnish topcoat to add durability. It would be purely an aesthic choice.
Latex wall paint is not a good choice, in my opinio. If you are going to use a waterborne finish 100% acyrlic enamel will give a harder, more durable surface. With a top enamel, Sherwin Williams Pro Classic or Benjamin Moore Accolade. you probably don't need polyurethane either. But, the waterborne just won't be as tough as the oil based.
>Why doesn't a waterborne finish that's formulated to be walked on also work on a table top that won't be walked on?
I have finished tables exactly as described in my post, above, and they're just as durable as an oil finish. Oil is technologically passe.
Clint
Re: Contrary Opinion
Rick Van Schoick
>There are places where the veneer has disappeared, as you can see in the photo. So I don't think stripping and refinishing will do the trick. My original plan was to make a new top, but my TS doesn't have the capacity to rip anything wider than 24". So back to paint. I happen to have a gallon of Everlast oil-based Varnish/Poly that I'd like to use as the film finish over the paint, since I already have it. I imagine it will yellow the paint color, but since we're probably going to go with a darker shade probably not an issue. Plus, it should preserve the durability of the paint layer, right? Thanks.
No primer paint *LINK*
Michael Dresdner
>If you want to paint, the process is as follows; scrub the surface with mineral spirits or TSP on nylon abrasive pads, and wipe up with paper shop towels. The solvent will remove surface dirt, airborne grease or skin oil and wax while the abrasive pad abrades the surface enough so that sanding is not necessary.
If you already have oil based varnish you want to use, simply add pigment to it and make it colored varnish, another name for paint. Use artist's oil colors and you will be surprised how quickly it will make the color you want. You can omit the primer with oil based material over finish.
Otherwise, buy oil based paint in the color you want and use that. Again, layering different materials simply makes more room for problems. If you buy oil based paint, there is no need for clear topcoat.
By the way, there is now a paint on the market that needs no primer, goes over and adheres to any surface including plastic, wood, glass, metal and concrete, is for both interior and exterior exposure, is oil based for durability, and comes in an aerosol can with a comfortable trigger, instead of those annoying button tips, that will spray in all directions, including upside down. It is called Universal. Very cools stuff. Here's a link.
http://www.rustoleum.com/CBGBrand.asp?bid=16
Re: No primer paint
Rick Van Schoick
>Thanks for the info. Very good to know.
Rick
Re: No primer paint
Rick Van Schoick
>I have a number of Trans Tints. Can I use these instead of artist colors in the oil-based varnish?
Re: No primer paint
pecker
>I bought a can of that universal spray paint recently, and was seriously disappointed with it. The "comfortable" trigger, had a very mushy feel to it...there was a second or so delay when I let go of it before the paint stopped coming out.
And the spray pattern was like poor atomization...lots of splatters and an overall poor quality finish. Perhaps I got the one bad can off the display rack, but I'm not gonna buy another to find out.
