Plywood for cabinet doors
Alan Young
Alan Young
>I have project coming up that will have 10 doors. They will be aprox 18" by 32". I want a clean contemporary look and am thinking about using plywood with a thin edge banding around the perimeter. How flat can I plan on these staying? Will I need to plan for latches at upper and lower ends? Frame and panel will be a bit busy for this project...
Alan
Re: Plywood for cabinet doors
howard
>Alan, I've produced very nice slab doors from veneered plywood. As long as the sheet starts out flat, you're good to go. Solid wood edging will provide a little extra rigity.
Fred Davis
>Check out your lumber supplier for Lumber Core veneer , makes very flat doors and has a acceptable edge.
FredD
Thomas S Stockton
>Hi Alan,
When I have to make doors like that my preference is for MDF core. It tends to stay flater and usually I find that the face veneers are nicer. My first choice for veneer core would be what on the west coast is called pro-core which is a veneer core center whith a layer of mdf the face veneers are glued to.
Tom
Yonak
>On the other hand, I haven't had the good luck of some of the previous posters in this thread. I've had to replace 4 doors that were made of hardwood core maple veneer plywood in my parent's kitchen due to warping. The boards were flat when I made the doors, but after a couple of months they warped by as much as 5/8". I've replaced them with standard panel-style doors.
I'm now suspecting the stock was not totally dry when I worked it. It was purchased at a wood yard that specializes in sheet goods, not at a big box store.
When I posted my problem with what to do about the warped doors on this forum, I was roundly criticized for using that method of construction. One person said it was a "recipe for disaster."
Fred Davis
>Alan,
when overlay back beveled cabinet doors were popular in California, in the seventies I made thousands of doors using lumber core Ash made in Japan and sold by J.E. Higgins Hardwood Lumber and routed designs into the face of them using a Stanley Door Template Machine made for that exact operation.
Never had a warped door or a call back due to warping.
On the other hand if you want to expose yourself to "being roundly criticized " unrationally in most cases, this is the place to go. ;-))
FredD
Jack
>Hi Alan
I own a cabinet shop and we've given up on building plywood doors. Keeping them flat is a crapshoot on a good day. The doors you're planning are fairly large so that won't help any either.
When we need the plain, contemporaray look you're after, we've found that veneered/edgebanded MDF is the way to go. I'm sure the lumber yards that supply your local cabinet shops carry it in a couple of common species. As I'm sure you know, MDF is not without it's own problems. Hinge screws will pull out in short order. We use the Blum press-in dowels for our hinges and have never had a problem with them. Good luck
Jack
