Cutting veneer - to the left or right of the blade
Louie Lovas
Louie Lovas
>Just interested in opinions and others experiences...
In cutting veneers on a bandsaw which is a better setup.
1. Setup the fence so the sheets are cut between the bandsaw blade and the fence (like a traditional cut on a tablesaw)? what I'll call the left side of the blade as you're facing the cutting edge of the blade.
2. Setup the bandsaw so the sheets are cut on the right side of the blade?
With option 1 (left) the sheet is trapped between the fence and the blade during the cut. With option 2 (right) the sheet is free after it passes the blade (and the pressure from a resaw fence).
I have used both setups myself. Option 2 means you have to keep resetting the fence for each cut (a pain). But I've also notice as you cut sheets from a milled board, you start to release internal stresses from the drying process - causing the board to warp and twist. You can go through the process of re-flattening the board but I've found that option 2 is a but more forgiving when the board is not quite so flat and true.
Any opinions & experience welcome, thanks.
Louie
Re: Cutting veneer - to the left or right of the blade
Alexander Grigoriev
>Modify the fence so that it ends after the blade
>Good Morning Louie,
I usually saw veneer @ approx 3/32 or heavier from jointed stock placed against the resaw fence to the left of the blade. The veneer peels off from the right of the blade.
I run the stock thru my thickness planer and true up the newly cut surface. Then repeat the process. This gives me one nicely surfaced facing. When I get enough veneer cut, I use a veneer sled in my planer to dress up the rough side to universal thickness.
I would use a Performax sander if I had one. However, the method I use seems to produce acceptable results.
George
which Blade?
tek-Brunswick, Ohio
>Which blade are you using George?
howard
>I resaw with the cut-off piece between the blade and the fence. No issues with binding or kickback. Use a 1/2" blade with 3TPI.
Brent in Montreal
>I cut with the piece between the fence and the blade which has the veneer falling to the right of the blase. I recently installed a Driftmaster fence on my LT18 which makes resetting the fence a breeze. Just a crank or two and it's ready for the next slice.
Paul Waddle
>Which is the preferred method-I'm confused?? Why not have the cut off pc to the left of the blade as no fence resetting is necessary. Joint the larger pc for a repeat without resetting the fence. What Am I missing?? I'm wanting to do better.. pw
Re: which Blade?
>Good Afternoon tek,
I use a Timberwolf 105" 3 tpi 1/2"wide resaw blade on my 14" Jet band saw w/riser block. . I also used a 3/4" wide Timberwolf resaw blade on my son's 14" Jet without riser block, but didn't like it at all. Cuts were too corse.
George
Brent in Montreal
>Hi Paul, with the DM you just joint once to get a square face and side to meet the fence and table. Cranking the same amount each time gives you thicknesses within a few thou. Trying to manually set a fence to this accuraccy and jointing each time is time consuming.
William H. Falberg
>When cutting multiple veneers off a workpiece it is obviously preferable to set the fence once and cut successive veneers from that consistent setting. The problem with this method is that the off-cut piece, the veneer, often warps when released from the "motherboard" and pushes the workpiece off the fence, making it almost impossible the stay in line along the fence. I also noticed that sawdust gets in the kerf, at the bottom, to further force the workpiece away from the fence (this, too, needs addressing). The solution is to end the fence immediately behind the blade and to extend the table's support surface as far beyond the blade as it is before the blade, consistent with the length of the workpiece you want to cut. For truing operations, where the off-cut is outside both the fence and the blade, you would need the fence to run full-length before AND after the blade; with table support for the weight of the workpiece also present both before and after the blade. You'll need TWO fences to do two distinctly different jobs correctly. I just learned this a couple days ago. I'm now working on a "convertible" fence solution to satisfy both the veneering and the truing functions, but I think ultimately we'll need two different fences.
Paul Waddle
>Is the DM an adjustable fence system? I'm sure the finished side can be sanded as cut veneer this way, is plently thick. If the jointer is not set just so,an error can be introduced,but how about the accuracy of a DM(?) Will you link me to a picture? Thks,pw
Re: Cutting veneer - to the left or right of the b *LINK*
Brent Smith, Montreal
>Hi Paul,
Here's a link to it. You can link to photos and video from this page.
Drift Master Fence
Paul Waddle
>Thanks for the link. I see where DM comes from. Laguna products are excellent so I'm told. One can take advantage of the accurate settings to do the veneering on the outside(right) of the blade. Money is my only woodworking problem,had to forgo a hollow form boring system for that same reason. That was one good dicussion on that subject last evening.pw
