Questions about window casing
John_in_Az
>Hi All - I am about to trim out 12 replacement windows. I have a large supply of 4/4 Poplar and am looking for advice about making my own casing. I have more time than money, and since I have plenty of material and no storage room I want to make my own. I just want a simple wedge casing about 1/4" on the narrow edge and about 9/16" on the wide edge, and about 1 5/8" wide.
As I see it I have a couple of options: 1. angle the blade on my table saw and edge-saw, then cut to width. 2. face glue two pieces of the 4/4 (13/16" now) which would give me the 1 5/8" width, then angle rip. This would result in less waste and since the casing is to be painted I don't see any downside. Anything I'm missing here?
I just don't see paying .70+ cents a linear foot for casing that is just MDF at the borg. I don't have any other local source for material.
Thanks, John
Re: Questions about window casing
Planer sled works
Bill Howatt
>I have made simple casing by ripping at about a 5 degree angle, sanding and then routing the edges with a small round-over bit.
I just made some out of cedar (old T&G siding). I cut the stock into 2" wide strips which was the width I wanted. I made a sled for my planer out of some ply and fastened some old casing to it with about 3/4" wide plywood strips along each side of the old casing to hold the stock on the old casing properly. The old casing provides the tilt on the stock to get the correct bevel. I made sure the narrow plywood strips were below the cutter height and used brass screws to fasten them just in case of accidental contact.
After planing to the correct thickness I then ran them through the router table with roundover bit to dress the two edges. I could do the 4 pieces for each window at once with the sled.
Bill
Fred Davis
>Forget number two, why have a glue joint when you don't need one?
For number one, rip to width first , then turn on edge and rip the angle cut.
Bill's idea works pretty good if you have a planer and router table.
If you have a buddy with a Williams and Hussey moulder , then he could run it with one pass.
FredD
John_in_Az
>Thanks for the responses, Fred, your advice is well taken and that's the way I'll go. Bill, your planer method sounds great also, but I'll probably never make casing again and don't need another sled/jig kicking around.
One more thing, my cabinet saw is right tilt and I know the safest way to angle rip is with the fence to the left of the blade. However, I have a pair of Grrrrippers (recently purchased) and I wonder if I can successfully do it with the fence to the right of the blade? I much prefer working on the left of the fence if possible.
Thanks again
Fred Davis
>Depends on how fast you or anybody unfortunate enough to be standing in line with the trapped arrow you will make can move.
FredD
John_in_Az
>Fred, that was the point about mentioning the Grrripper push blocks. If adjusted correctly they hold both sides of the cut so you can push the piece next to the fence through past the blade. Should be no "arrow", but I've never used them on angle rips so that is why I asked.
Fred Davis
>I am not familiar with grippper blocks , but if they let you trap a ripping and surrive , then go ahead on ;-))
I wouldn't been surprised if you get some burn marks on your stock, but only way to see is to try.
FredD
Kirk Constable
>We've just purhased a 60 year old house... so I'll speak as the guy that might need to match something in 20 years that you do today. Use standard casings that I can go to the HomeDepot and buy for 70 cents/foot.
kc
John_in_Az
>Well I don't want to beat this thread to death since apparently not too many people are interested. But, it is important to me and I'm not getting any BTDT responses, so here's the deal.
I contacted the manufacturer of the Grr-ripper system and spoke with the inventor/owner,Henry Wang,and he is confident that I can do this procedure safely and successfully,with one caveat. If you don't have the deluxe 200 system (which I don't) I need to make the simple addition of an extension to the balance foot to make sure the stock is kept tight to the fence.
I will do some tests and if all goes well I'll make my cuts. I will let you all know how this turns out. Don't expect feedback too soon as I won't be doing anything for about two weeks since I will be trimming the exterior first and need to prepare the stock.
And Kirk, I could give a tinkers you know what about 20 yrs in the future, since this POS 20 yr old manufactured home won't be around that long. LOL. Later, John
Fred Davis
>John ,
POS is pretty transparent, but I am still working on BTDT and good luck on the milling ;-))
FredD
John_in_Az
>Well, to those who were holding their breath waiting for the results of my quest to make my own casing, here it is.
I attempted the job on my table saw and after the first cut realized it wasn't worth the effort to me. I just didn't like the plain straight face. I decided I wanted a molded contour face and also changed to a wider 2 1/4" casing. So I chickened out and bought premade at the borg.
I discovered that there are some things that are better bought premade. Expensive yes, but I still have my sanity and all fingers. In reference to the fingers, the operation was doable,but not safe IMO,and as others have stated if in doubt don't do it. John
Bill Howatt
>If you are happy and safe then you made the right decision. Over the years I have seen a lot of people come to grief trying to save a buck and ending up with an unsatisfactory job or worse!
Bill
