>Has anyone restore the vanish on an old 1943 lane cedar chest? The veneer is in good condition and barely damaged. The lacquer is flaking off, leaving bare and unprotected areas. What is the best way to remove the old lacquer and give it a nice new clear coat?
>I inherited a couple from my mother. One had a damaged lid -- I lightly sanded it and gave it several coats of wipe on poly. Not a good way to "restore" an antique, but it works if all you want is a usable chest.
I also oiled the insides with some cedar oil to restore the classic smell.
>I have restored a couple of old Lane Cedar Chests. The ones that I worked on had a shellac finish. Shellac can be restored by re amalganating(SP?) the finish. You could strip the old finish with denatured alcohol and reapply the finish of your choice.
I have some experience with Lane cedar chests and can offer a few pointers. Your Lane chest has either got a lacquer or shellac finish. The easy way to tell which is by wiping lightly with a cloth dampened with the respective solvent. For lacquer it would be lacquer thinner and for shellac, denatured alcohol.
I'd probably try the alcohol test. If the finish feels sticky to the touch, it's shellac. If not, it's probably lacquer. If it turns out it's shellac, you can revitalize the finish by wiping it down with plenty of denatured alcohol and rags. You could also use straight household amonia as well. You don't really need to remove all the old shellac because a new shellac finish will "melt" into any old that remains. Once the surface looks right, apply your new shellac finish.
On the chest I recently refinished, the old shellac was in bad shape but the wood had scratches that needed to be removed. I stripped the entire exterior sanded it, and finished with Waterlox, which is a tung oil based varnish.
>I have also refinshed several cedar chests (including a couple from lane). If the finish isnt that bad, revitalize it be doing what the previos posts say. if it truly is bad enough, and needs to be stripped, I use zar furniture refinisher (it is a stripper that will remove lacquer and shellac). i then apply a light coat of the satin than matched the previos finsih, and finish with oil based poly or lacquer...whever the customer wants. make sure to remove all of the hardware, including hinges, locks, etc. then sand the inside and apply cedar oil.
>The safety recall is still in effect. Anyone interested needs to have the style and model numbers, located on the bottom of the chest, and latch shape available to give them. The order can be placed on their Website form or by calling 888-856-8758.
I ordered a new lock and latch for the chest I recently did. Four weeks later all I got was what they called a "no lock latch". I called them to ask why there was no lock and key. They said their solution was this "no lock latch", which is just the latch base without the little "bar" that the lock catches. Because the adjustable spring lid supports kept the lid raised about half way when open and adjusted out as much as possible, this new latch was of no use. I ended up cleaning and polishing the old hardware and using that to keep the lid closed.
Was surprised to see your question as I just refinished a 1943 Lane cedar chest that was my father's first furniture gift to my mother when they married. The top and front had some faily complex walnut veneer inlays, typical of the early "modern" era designs.
My finish was shellac and because of some scratches, I stripped it by rubbing with a cotten or terry cloth rag dripping in denatured alcohol (which you can get at Home Depot by the gallon). Just make sure to squeeze the old finish out of the rag frequently and dip into clean alcohol.
I then used a random orbital sander (ROS) with 320 grit paper so I would not cut through the veneer. Probably could also have used 220 grit with a lighter touch. Sanding opens the wood pores and it took about 20 thin coats of shellac (two pound cut) to fill the thirsty wood and reach a deep rich finish.
The last step was to take very little liquid 3M "Finesset" (or you could use McGuires auto body swirl remover), and apply it to a lambswool ROS pad and buff with the sander. You will quickly get a deep, high gloss finish that lookes at though it had been done by french polishing.
