Tensioning wire?
Tensioning wire?
Tensioning wire?
>I've got to stretch some wire between pairs of uprights for a project I'm working on.
My initial thought was to use screw eyes in the uprights and just tug. Well, I'm not really getting the wire taut enough.
We are talking light gauge stranded wire. I suppose I could get some really small turnbuckles (if any could be found). Possible if I could find a really small wire clamp, I could tension the wire and keep it relatively taut.
Any other suggestions? Thoughts? TIA.
Re: Tensioning wire?
turnbuckles
Bill Tindall, E.TN
>of course you can get small turnbuckles. I have bought them at Tractor Supply. If you want some spiffy ones get them from an aircraft supply place. I used them for tensioning bow saws with 1/6" cable.
Paul Bunion bow saw?
Neal in San Jose
>That must be SOME bow saw if it needs 1/6" cables. Did you mean 1/16" by any chance?
Re: Really small ones?
>I can go by the Tractor Supply place in Ellijay on my way back up the mountain. I'd be wanting something that was ~2" long for 1/16" or smaller cable. I'd only have to put it on one side.
Lee Schierer - McKean, PA
>Can you put a hole all the wy through one upright? If so then you can use an eye bolt with a long threaded shank.
Another way is to put in your two screw eyes, attah the wire on one end and then mark the point on the other end where it just touches the other screw eye. Partially remove the first screw eye and remove the free screw eye and attach the wire to it after shortening the wire 3/4 of the length of both threads on the two screw eyes. Then count the threads and reverse twist the wire 3-4 more turns than the number of threads.
Start the loos screw eye into the hole and tighten it all the way. Once that one is tight, tighten the other screw eye. The wire should be pretty tight.
Lee
>For light gauge wire, I might consider using springs to maintain tension.
We use inline ratchet tensioners and crimp connectors for 12-9 ga high-tension fence wire, but I don't think they make them small enough for what you need. Twisting a loop of wire with a stick will also tension it as much as you desire (until it breaks).
