OT - hanging elec boxes...
Brian Gray in Sandusky, OH
>I'm hanging electrical boxes this weekend in the new shop.
I just thought that I'd ask if anyone has any general advise about spacing, height, placement....
I've heard that I should hang more than what I think that I need.
I'm doing that.
Recommended spacing for my 110 boxes?
I will hang six 220 boxes, 4 on one long side of the shop, 1 on the back wall, and 1 on the where most big tools will be stored. Anyone think that I might regret this someday?
Maybe put another on the other wall?
Just checking out general advise....I have a schematic drawn out, I know exactly where each tool will be located, and I'm placing boxes accordingly.
I know where benches will be, and I'm hanging boxes to above bench height in those spots.
Re: OT - hanging elec boxes...
mdclor
>Brian,
I have my 110 boxes 50" off the floor and spaced every 4 feet. You know where your tools will be initially, but things have a way of changing over time. I also put a couple in the ceiling for my work bench, air cleaner and anything else that might be handy for island type tools. The 220 boxes I located where I thought I wanted my major tools and already have made 2 changes and I have only been in the house for 6 months. The problem with them is that some tools require 20Amp and others 30Amp, so you don't have as much flexibility as you do with 110.
HTH,
Merle
Howard Norman
>You are unlikely to regret putting in an electrical outlet box. I never have, either in my shops or in this house when I built it. In my Phoenix shop when I built it I installed the outlets 50" off of the floor and every five feet. The five feet was because I was using 10' EMT conduit and that way I could just cut a section in half. I found that worked very well for me. I also recommend that no two adjacent 110 outlets be on the same circuit.
Gil Jones
>I also put several 240vac recep. in the ceiling
Randy Johnson Connersville IN
>I wired my shop before the price of wire went out of site. Since it was affordable, I installed a lot more dedicated 110 receptacles than I really needed to. My shop is in what was an existing garage on a slab. Since almost everything requiring 220 (the exception was the dc)was out in the middle of the floor I fed those machines by running EMT overhead and dropping to the machines alongside the dc ducting. This also allowed me to install two duplex outlets on the side of my tablesaw outfeed table so I have somewhere to plug things in besides the outside walls.
The dedicated 110 circuits saved me a lot of trouble when the lathe (which I never imagined I would even want, much less have) arrived. Things had to be rearranged anyway, and all that was needed to have a 220 receptacle for the lathe was swapping out the plugs and a little rewiring in the panel.
I haven't priced wire lately but I think it's still more than twice what I paid for it. Just like the cost of gas has cut down on driving, the cost of wire might make running a lot of extra circuits something you won't want to do. But,if you can have at least one or two dedicated 110 circuits on each wall you might be glad about it sometime in the future.
Larry Clinton At Frankfort (Central)., Indiana
>I installed 120V outlets 50" high on every other stud (16 on center) 32" apart on every wall in my shop. I also installed about ten 30 amp 240 Volt outlets, and one 240 V 60 amp for my welder. I installed 3 rows of outlets across my shop ceiling. Each row is on a separate switch by the entrance door. These are very handy to plug in the 4' florescent shop lights. All of the shop lights I have purchased come with a short cord and plug. Later replacement of the shop lights only takes a few minutes as they are plugged in - not hard wired - and hun from short chains. In addition I installed 5 Incandescent porcelain outlets around the periphery of the shop ceiling - I have 100 watt halogen bulbs in them. I installed one 120V outlet on the ceiling for the garage door opener. I wish I had installed some more outlets right next to the garage door and entrance door so it would be more convenient when sanding outside etc. I also installed an outdoor light circuit with switch (security light), over my entrance door. I would have installed a couple more security lights over my garage door, but the ones on my house covers that area. I am sure glad I installed so many 240 outlets. Since I built my shop about 4 years ago I have replaced several machines. My air compressor, dust collector, 20" stationary planer, Unisaw, MM16 band saw, surface grinder, Lathe and welder all require 240. Note that you can always make extension cords with a 30 amp plug and a 20 amp receptacle to plug in 20 amp equipment (or change the plug on the equipment to a 30 amp) and use the 30 amp circuit legally. You CAN'T use 30 amp equipment on a 20 amp circuit however. The circuit breaker size is to protect the stationary (wiring and receptacle) wiring - not the equipment. I have several extension cords made with 10/3 w/G flex wire so I can position my tools anywhere in the shop. I have a room over my shop so I also installed several outlets there (no 240) and 3 way light switches upstairs and down for that lighting. If you have a storage area there you probably want to install some lighting. I installed a 100 Amp main in my shop (fed from my house 200Amp box) I have used every circuit - almost wish I had installed another sub- panel. I did use "cheap" outlet receptacles - I have been an electrician for many years, and believe it is far better to spend your money on extra circuits than expensive receptacles. I can replace any receptacles in less than 10 minutes that do wear out, and will then use a heavy duty unit. The bulk of the receptacles will never get enough use to wear them out - but are sure handy when you need to use one where they are located.
Dale Lenz
Dale Lenz
>I put the top of my plug-in boxes at 4'. If I lean a 4x8 sheet material against the wall, 8' side on the floor, it covers my outlet. So.......recommend the bottom of outlet box at 4', this way if you are using 4'x8' sheet material to panel the shop on it's side you only need to cut 3 sides. Believe I spaced my 110 outlets every 6'-8', good spacing for me. Twelve years ago, cost me less than a dollar/drop for materials, box, outlet and wire nuts.
Fred Davis
>I have always had a 4 square box with double duplex receptables 120.V attached to the back side of my cabinet saws tapping into the 240 with ground I always run to any machine in case it had a work light, powerfeed etc running on 120.V
This a handy place to have them, right at the workbench/outfeed table and elimanates the need to have extension cords run on the floor.
FredD
>However many you hang (every 4', 32" or whatever), make sure they are not on the same circuit. Alternate it so that you have circuit A for one receptacle, circuit B for the next and maybe circuit C for the next. Then go back around to circuit A. That way you don't have adjacent receptacles on the same circuit. That way you can have a shop vac on one circuit and a router on the next.
Just a thought. Of course if you have two circuits in the same receptacle..
Outlets on 20 AMP circuits
howard
>I just finished wiring my new shop and I learned from this site that all outlets should be run on 20 amp, 12 gauge wire. In fact, my local code requires it and I think many others do. I made a mistake and ran 14 gauge, which I then had to remove and redo.
Tony - Memphis
>Well, you covered everything I would have suggested. I put in a new box for a 220 outlet this weekend. I'll have it wired. One thing I read about before I built my shop was to have all the circuits controlled by switches so you can turn them off as you leave and know that everything is off. I did that and have appreciated having it done that way.
Oh, what about ceiling outlets for air cleaners and such?
Enjoy the new shop!
Tony
Joseph Mulherin, Sr
>Brian, when I built my shop in 1987 I also upgraded my elec service to 200Amp. Took the 125 amp box and installed it in the shop and ran 6 individual 110 lines and one 220V line for my RAS. Spaced the 110 lines about 7ft apart, 2 on each wall. the other wall was the garage door wall. It has allowed me to use all my hand tools with efficiency and the motored tools are easy to connect to such as the Shopsmith, planer, bandsaw, router-table...etc. First off make a drawing of the placement of your tools and then decided where you need the outlets.
