Veritas - Innovation in Tools
Repairing a Mirror Frame
Ken Krawford
>My daughter-in-law dropped an old mirror and broke the frame. There is a lot of decorative scroll work made of what appears to be plaster of Paris that shattered.
Is it practical to fix something like this? What do you use to "glue" the broken plaster back together?
Thanks.
Re: Repairing a Mirror Frame
>Some of the ornamental scrollwork on frames and the like are cast plaster (or resin nowadays) as you have discovered. Inexpensive to make (and reproducible).
Is it practical to repair it? Without a picture it is hard to say. How much of the scrollwork was powdered? Can you find all of the pieces? How many gaps need to be filled? All of these things need to be taken into account. If you have the majority of the work without too many gaps, you can probably repair it.
As far as adhesives, I'd vote for a nice 2 part clear epoxy. Wear gloves (nitrile or latex) that fit closely. If you need to fill gaps, Bondo works great.
My $0.02.
Ralph Lipeles
>Plaster is porus so I would expect that regular yellow glue would work well. As far as filling, I would use regular wood filler.
Ralph
Re: Repairing a Mirror Frame - question
Ray Carson - Lawrenceville, NJ
>Is the glass broke? I'd be more worried about the 20 years bad luck. Just teasing Ken. I hope you can fix the mirror. Good luck.
Ray
Ed Mulligan, Cape Cod
>As a practical matter it would be easier to just find another old frame.
If you want to proceed with the repair, here's what I'd do: The plaster design usually repeats around the frame. Find a spot that repeats the broken section. Take an impression with dental wax. Fill the impression with thickened epoxy or plaster of paris. When cured, pop it out and glue it into position. For glue I'd use thickened epoxy.
Ed
Ron Bauman
>Depending of the age, what you've got is probably Gesso not plaster of paris, although it is a component. There are lots of recipes (check the internet). You could acquire some dental casting medium and make a copy of the pattern if it repeats on the frame and then cast a replica and fit it into the broken area. All time consuming and tedious unless there is true value to the frame.
