Advice to eyeglass wearers
Tom Pilsbury (Chicago)
>No matter how clean that piece of cloth in your shop looks, DO NOT use it to clean your eyeglasses. I ruined a good pair of reading glasses yesterday by wiping them off with what I thought was a clean cloth. That fine sawdust that you can't see gets on everthing (including the inside of your pocket) and will scratch the lenses of even the most scratch resistant coating.
So it's off to the eye doc today for a replacement pair. You can bet I'll take much better care of the new ones. Hope this post saves someone else from the expense and hassle.
Re: Advice to eyeglass wearers
Lee Schierer - McKean, PA
>When my glases get dirty, I clean them with hand soap and soft water. I wet my fingers and the lenses, rub the wet fingers on the bar of soap, then rub the soapy fingers on the lenses unde a slow stream of very warm water. When the lenses feel squeeky they are clean. Rinse off the remaining soap and pat dry (no rubbing) the lenses with a soft cloth. Repeat if you see smudges. I generally get smudge free results.
Lee
Jason Roehl in Lafayette, IN
I used to do that...
>...but I noticed that when the glasses got cleaned at the optometrist's office, they were much cleaner than I ever got them. So I asked them what they used, and they showed me. It seems to be a soap solution with alcohol in it, I can get it at Meijer's--I keep several bottles around--one in the bathroom, one in my work truck. I've also noticed that the retail cleanser helps prevent fogging better than hand soap.
Also, never, never, never clean your glasses with any wood-based products--TP, paper towels, etc. They will scratch your lenses up in no time. Once I learned that, my glasses would go from maybe a year before they were too scratched up, to 3-5 years before they had noticeable scratches, even my work glasses which get cleaned constantly (painter...).
One more thing, it also helps to rinse or blow off any dust before you clean them, otherwise that dust can serve to turn your cleanser into a sort of slurry.
Jason
Don in Vancouver,WA,USA
>I buy a box of 50 individual packets of pre-moistened lens cloths. The ones I have now are by Zeiss but there are several other companies that make them. I keep some in the car, shop, etc. The work ok on computer screens, etc.
>I use ZEP Tub and Tile Cleaner, hot water rinse, and any handy towel.
Clint
BrianA
>I use comet cleanser. But after the first try, I could not read the label, but boy are they clean;-)
My glasses guy says…
Rod Peterson -- Ormond Beach
>…there are two rules:
  1. Always cloth…
  2. Always wet.
This last pair has lasted much better with that regimen than previous sets (I'm on twenty+ years in reading glasses).
Rod
LOL ;-)
David Yoho
Don't use TP? That could explain......
>why I hvae scratches on my......
And...
Rob Lee
>... the same goes for wiping Elk drool off the window of your brand new vehicle with what looks like clean white fluffy snow....
I looked at those scratches for three years less two weeks....
Cheers -
Rob
Ralph Turney
>For the last 15 years or so, I would just run nothing but hot steaming water on them (no cold at all) and then clean them with a few old cloth diapers that I used for nothing else and the lenses ALWAYS out last the frames and for a few of those years I was a concrete cutter. Nothing is more abrasive than concrete slurry.
However, now I don't care, because I just had my lasic redone yesterday and not only can I see perfectly far away, but I'm even typing this without needing reading glasses (I'm 52 by the way).
Sorry, I just couldn't help the personal gloat!!!
That is why I have glass lenses
Wayne Carson "TX"
Re: That is why I have glass lenses
Ralph Turney
>Mine have been plastic for years and with the method I use they stay perfect without the weight of glass.
Same here!
>Mine are the ultra-high index of refraction just to keep them as thin as possible. I wore glass lenses as a child, and while a distant memory, I still remember having sores and redness almost constantly on the bridge of my nose from the weight. I do pay a premium for my eyewear, though--my last two pair cost a total of about 8 bills...so I definitely try to get as much out of them as I can. Of course, I did break one of the frames, but SWMBO got online and found the exact frames--for 60% of what I originally paid for them...arrrgh.
Jason
