Re: Experimental resaw fence
William Falberg
>The two slides have four thumbscrews which lock onto the edges of the tabletop. It only takes one twist to turn a slide into a lock and when you tighten the top rail (the angle attached to the saw frame) it pushes the fence down further, reinforcing the whole fence. For me, the fence (as well as the blade, the saw, and everything else) has to withstand "nudges" from 200 lb. chunks of whatever. Without that stipulation my solution would look like just about every other fence on the market. Likewise, the blade's angle to the table becomes critical when you're working with 14 -16 inch cut depths. And that's the crux of the matter. The fence has to be strong, yet micro-adjustable throughout the throat's width range for the professional woodworker to take it seriously. On top of all that it has to be a quick and easy set-up. Previous prototypes have satisfied the strong and the micro-adjustable requirements, but the quick-and-easy part remains problematic when you demand accuracy throughout the full range of cut width. The ultimate goal here is to take a big piece of driftwood, a burl, or stump and square it off, true it, and cut it up into veneer without makling a career out of it. If I can figure that out it would make a cool after-market fence kit for those who already have the riser but still can't get good, wide veneer. I'll keep posting these prototypes and responding to criticism until the design is worked out enough to start producing them. That's how I did the saws. My customers designed them, I just make them. I really do appreciate criticism. I have thick skin so don't even try to be "nice". Like that robot in the movie, I run around "input, input, must have input!"
