Re: Fine points of lacquer repair
Kevin Hancock
>Those vintage Steinway grands were very pretty pianos. The mahogany cuts were outstanding.
Repair to sunlight damage is a little daunting, but improvements are very possible. Un-doing the damage without refinishing is pretty impossible, as much of the damage in the color of the piano is actually in the finish and is seen as a yellow semi-opaque faded and cracked coating. Results of this repair process will vary depending on the level of damage.
What I've done in the past is to smooth the surface with 400-600 finishing paper. I like the 3M 216U gold paper and use it dry. If there is any wax on the surface, a wash with naphtha might be in order. With the surface clean, pad on a NGR dye mixed to desired color. I've used solorlux for the task, but Mohawk and others make similar products. You will have to apply in quick passes and get a feel for what it takes to amalgamate the surface without getting it too wet and gooey.. The colorant should bite into the fine cracks and crazes and mask much of the yellowing. Apply only what is needed to get the surface looking better without getting the surface softened too much. Sorry I can't describe in writing exactly how much that is, but I don't like to get the surface too soft as it will stink to high heaven and take a long time to dry. Give this step overnight to dry.
By the way, you will need good air movement in the room where you are working and use gloves for hand protection.
Once the color looks better, French polish the surface with shellac. I like the mix in Stars, LacFrench for this task, but again, you can choose a French polishing mix, based in shellac, that you might prefer. The first few passes will be the more challenging as the solvents will be pulling some of the colorant out of the finish. Don't worry that your pad is collection dye, but do try to avoid streaking the colorant and creating a muddy mess. Make a quick pass over the surface and let it dry for 15-20 minutes and make repeat passes as needed. I use straight long fast passes to apply the FP and gauge my pressure based o nthe wetness of the pad. As the finish builds, you can use less wetness on the pad and burnish the surface to get rid of the streaks in the surface.
I hope this is helpful. The combination of the dye and shellac will work nice to soften and re-melt the finish, but will only mask the sun damage.
Kevin Hancock
