Quick opinions sought on Makita 2010
North of the Border
>My neighbor is getting rid of his Makita 2010 12.5" Made in Japan thickness planer plus a pair of new blades ($50 value he says) for $185. This is the old model where the table moves up and down (instead of the 2010 NB). Is this a good deal not to miss? I went to HD yesterday but there wasn't a Ryobi Ap left (stores at other locations have them).
I can't build a infeed and outfeed table for this older model as the table moves up and down. That's a drawback I'm concerned with planing long and large piece. Does anyone of you have experience with this planer. Thanks.
Re: Quick opinions sought on Makita 2010
>Good Evening Woodguy,
My opinion is that the Makita isn't going to satisfy your needs if you can't build the in/outfeed tables consistent with your work. It may be a very nice, reasonably priced, and well kept tool as is. I just don't believe it is YOUR tool. Keep Looking.
George
wooden leg
>I don't have that model but I do have a Sears planer where the table moves up and down. If I ever had to buy one I would not get this type of planer again. It works okay for thick stuff but for anything under a half inch it will not give good cuts all the time and I think it is because of the lack of good infeed and outfeed tables. I built tables for certain sizes and built a carrier for thin stuff, it just takes too much math to figure for fun. Dave
Timely advice - thank you
North of the Border
>Can you believe this: the guy raised his asking price by $15 after several people inquired about it! I took advice from both of you and walked away from it.
Kneale Brownson dreaming of snow in N. MI
>I have a large 18-inch Delta Rockwell planer that the table moves up and down on. I use adjustable roller stands if I feel the need for support for longer boards. I don't see any difference in cut in the middle of longer boards, but I'll occasionally get a bit of snipe at each end if I don't lift the board when inserting and removing.
rollers
North of the Border
>The use of rollers seems to be an alternative to building shop-made infeed and outfeed tables. But my garage floor is not level and leveling the board with the planer table may take a bit of time ....
Re: rollers
Ralph Turney
>I've had this planer for at least 15 years and have never had a problem with it (except for maybe the neighbors complaining about the noise :-)) and I've never even thought of the table moving up and down as an issue. I've never had the room to build dedicated in and out feed tables for it. I have a very easy method for long boards...I use an old Workmate and a piece of wood that's about 12" wide and maybe 2' long and clamp it between the two pieces of table top sticking straight up and eye ball level. I just eye it to the height of the planer table and it works perfectly, no need to get out any lab equipment. Just so long as the "out feed board" is a little lower than where the board will be at that point it's all good. It's very simple and also very quick to set up and take down.
Of course, 200.00 may be a little steep for a planer that old. I think I just paid about 30 or 40 dollars for a couple of sets of extra blades.
Re: rollers
North of the Border
>Thanks to let me know that. The new Makita now has the cutters going up and down instead of the table.
