Leaning Dresser - how to
Jeffrey D. Rose
>I am sure many of you have seen the artistic leaning dressers. Some appear to be slightly curved, others are wide at the base, narrow at the top. But they lean to one side in a whimsical fashion. Well, my mind has been going nuts figuring out how these are made. Does anyone have an idea or a website link that may show more detailed pictures? I would hate to think that drawer and dust frame is custom fit without some idea of the size, shape, etc before the construction begins.
TIA
Jeff in Iowa.
Re: Leaning Dresser - how to
>I have no links at the moment. The straight sided ones are generally just a result of creatve geometry. Essentially working outside of the normal 90 degrees. Fun if you are math inclined. :-)
The curvy ones are generally created with bent lamination panels with the help of a vacuum press. However, they too require some funky geometry.
Sometimes the curvy ones will have curvy drawer fronts to match the case but have straight 90 degree boxes for the drawers themselves. Much harder to make the entire drawer curve to match.
Tom
Process
>Wild and whimsical pieces like this must be drawn out carefully and to scale. Then you can use your scale drawings to make laminating forms for the curved parts of the case. Once the case is together, you lay out the locations of the drawers/doors/whatever and make the drawers, dividers, etc. to fit in their exact location.
That is a pretty gross oversimplification, but it is a general idea of the critical path.
Ellis Walentine, Host
Alan in Little Washington (NC)
>You need to get your hands on the latest issue (Sept 2008) of American Woodworker. It has an article titled "The Fantastic Furniture of Judson Beaumont" He is famous for his whimsical furniture:
Jeffrey D. Rose
>I will certainly get that issue! Thank you for all your help everyone. It is starting to make a bit more sense. My biggest issue was with drawer construction. I have Autocad so drawing the dresser wouldn't be hard. Maybe I will work on a miniature and see what happens.
Jeff in Iowa.
