>I am making a Bulldozer toy out of wood except for the hard rubber wheels. I am having the hardest time putting a center at the end of a dowel. I have to turn down a 1 1/4 dowel to about 1.062 O.D., using my lathe and Super nova chuck. Then I need to drill a 1/2 dia. hole so that a 1/2" dia. shaft (axle) can pass thru the hubs. The finish hubs are 3/8" wide (basically a thick washer). They fit on each side of the tire. The outer edge fits into the curve of the tire that is just outside the tire I.D. I have tried making perpendular lines with one of those V-tools and have no luck there. I seem to do better just putting two cross lines using a ruler. The punch center that my awl makes is just off more than I would like. The center does not have to be in the exact center.
If I understand you correctly, I usually mark and drill the the holes on the lathe.
I chuck a piece of wood, perhaps turn it round, flatten the end, then gently make a small conical divit in the exact center with the point of a skew chisel held flat against the tool rest. The skew must be held firmly against the rest and not be allowed to move or the mark may not be exactly centered.
For precision, I drill the hole on the lathe with a drill bit held in a Jacob's chuck that has a morse taper to fit the tailstock. A brad point drill bit with "wings" is more accurate than a standard drill bit since it works like a mini forstner bit.
If I don't need to be that precise, I simply hold the drill bit by hand, usually with vise grip pliers. To speed this up, I mounted the most commonly used sizes in wooden handles and added adjustable depth stop rings.
I haven't made any toy wheels, but I have drilled a number of spinning tops where the concentricity is important.
Another way to get the hole exactly centered with the object is to drill the hole first on a drill press, then mount the piece on the lathe with a mandrel the exact size of the hole or a pin chuck. A pin chuck can be made quickly: using a short piece of round cold-rolled steel the size of your hole, file or grind a flat on one side. Cut a small steel pin, say from a brad nail, such that the diameter is the same as the depth of the flat. Mount the rod firmly in a jacob's chuck on the headstock and place the little pin on the flat as you slide the piece of wood onto the rod. Twisting the stock slightly on the pin chuck will cause the pin to roll on the flat and lock the work for turning. Turn the outside and the hole will be concentric.
>One of those machined, stainless center finders I've thanked the Tool Gods a few THOUSAND times ! Fast, acurate and, even if the dowel is home made and not even, you STILL wind up centered. Can even extend it with a ruler. I think LV carries one now. Money WELL spent !
>Here s a technique I have used succesfully with standard sized dowels. You need to drill a similar sized hole in a small piece of wood and insert the end of the dowel through it.
The square surrounding the circle hits the tangents of the circle and each side is perpendicular to the oter, easily accomplished with a small square. The diagonal lines are then run through.
>I just made one recently. Mine looks like a t-square. There are two dowel pins on each side of the long edge of the T that are equally spaced on each side of that edge. Basically, two pins with a line down the middle. When you rest the end of your dowel on the the pins, the centerline will automatically be aligned through the center of the dowel. I draw a line there, then rotate it around 90� and draw another line. Where these two lines cross is your center point. Not my idea, I have seen the concept on several center finders. I just made my own for fun out of walnut and brass. Need to make another one. The first one is always a prototype!
>I found the center of Dowell using Google Maps (see link below).
Oh, not that Dowell, sorry ;)
The trick I've always used when making wheels is to drill the axle hole FIRST and then turn the outer perimeter of the wheel after that. Works everytime.
Not sure if that helps or if it's as useful as the Google Maps link ;)
>If you need to have a "thick washer" centered about the hole, start with the hole. Drill a hole in the approximate center of the dowel (3/8").
Then take the dowel with the hole in it and mount it on a wooden mandrel with a 3/8" tenon. The mandrel can be made from scrap in the chuck, and will be centered automatically. The hole will fit the 3/8" peg with a pressure fit that should be sufficient to drive turning the outer diameter to whatever you need.
>Works, about, the same as the center square on a combination square only fixed. This one is the smaller version ( 3 1/4" L )but they make a larger one now. I got this one from Micro-Mark but I'd almost swear LV has it now. Its like LV's saddle square, you can just flip it around with one hand and mark with the other. Fast, easy and acurate.
