A55 Smoothing Plane
OT-Computer Clock
OT-Computer Clock
OT-Computer Clock
Rick Jackson,TN
>Really off topic but noticed yesterday at work my lap top computer clock was 10 minutes slow. Never gave it much thought before. This lap top stays on the docking station most of the time, though last week I brought it with me to a off-site meeting and home. Any ideas what causes this to happen? Thanks
Re: OT-Computer Clock
How Old is the Laptop
Dustmaker Mike
>If you reset the clock and it goes slow again I would suspect the Bios Battery is going bad. Most time you can view the battery voltage in the Bios it should be above 3 Volts. If it is not then that is the cause if it is then I am not sure.
Re: How Old is the Laptop
Rick Jackson,TN
>Best guess 3 years maybe. Looked agin now that I am on it and it was at least 25 minutes slow. Where do I go to view that battery life?
Dustmaker Mike
>Well there are two different ways it could be done. The first and more common way is to hit F2 as the laptop boots up then get in the BIOS and look for PC Health. The other way that is common is to hit the DEL key while the laptop is booting up. You need to do one of these right after you turn it on just keep hitting the key. What I have done in the past if I was not sure was to go back and forth between the F2 and Del key just pressing them. If you see the screen about Windows loading then it did not go where you needed it to. look for a tab that says PC health or something like that.
Ralph Turney
>Double click on the time in the bottom right corner of your computer screen to bring up the Date and Time Properties window and select the Internet Time tab, then check the "Automatically Synchronize with an Internet time server" box. In the drop down you should have choices...pick one and then click on the "update now" and you should never have a problem with the time again as the internet times uses the atomic clock in CO.
Ralph
the problem is.....
Dan Donaldson
>That may make his clock be correct when connected, but it sounds more like the internal bios battery is going out and if that is the case, if not fixed, he will have more than time problems.
John McGaw
>There is a possibility of multiple issues here.
1) a PC's time is maintained when the computer is turned off by a physical clock on the mother board which is run by the same battery which maintains the CMOS settings for the BIOS. If this battery becomes weak the physical clock can become erratic, usually slow. As the battery becomes weaker the CMOS settings can become erratic which may cause no end of weirdness with the entire computer.
2) when the computer is turned on there is a virtual clock in software which operates by counting interrupts (think of them as periodic ticks) and deriving the time from that. This virtual clock is set by the physical clock when the computer is started. This clock can become slow if software is running on the computer and monopolizing the processor, preventing it from responding to the interrupts (ticks).
So, if the clock goes slow when the computer is off you should suspect the battery. If it goes slow when the computer is on you should look for a software problem.
