220 Outlet for PM2000?
Tony - Memphis
>Well, the post below may be a mute point soon. I've been leaning very heavily towards drawing off a new PM2000. One issue I have is power. I only have one 220 outlet in my shop and it is dedicated (lovingly) to my AC/Heater (which is getting a good workout today - 100�). To make a long story short, the best solution is to add a new dedicated circuit for the saw. I did some exploratory surgery this weekend and found that the cavity that my panel is in is the perfect spot for the outlet. I can knock out a hole in the bottom and run the wire straight down to a new box. Should be simple. I'm pretty confident that I can handle the electrical part, but I am going to hire an electrician to be safe and legal like. shouldn't be a big deal. I've read about the twist lock plugs here I think. So that's my question. What are they? My plan is to do all the mechanical stuff so the electrician just has to pull about three feet of wire and install the socket and the breaker. Seems like I read that a 20amp circuit is required for a PM2000. I have plenty of space in the box. Its a 100 amp service and there are 160 amps in breakers (40 for the ac - electric heat).
Tony
Re: 220 Outlet for PM2000?
>You would have a 13 amp 220V motor in a 3hp PM2000.
Yes, a 20 amp 220V breaker would probably handle that without any problem.
Twist lock plugs for 220V circuits are things like the L620P and the L630P (and the corresponding receptacles). You put the plug in the receptacle and twist it. The tab on the plug engages so the plug won't pull out. Excellent for overhead plugs and they work on wall plugs too :). Make sure you get the right receptacle for the plug you choose. The L620P doesn't work too well with a L630P receptacle, even though they look a lot alike.
You can get by with a L620P BTW.
Dan Donaldson
>Should be no problem. The twist locks just lock in so that you cannot accidentally pull it out. In most applications, it is not really important how many breakers are in the panel as they will not be used all at the same time. The heat/AC load would be considered 100% of their rating, so you have the equivalent of 60 amps available, but not at the same time, so you should be fine to add the 20 amp for the saw.
Fred Davis
>I am not familiar with PM's motor's since Jet bought them out , but I bought a new PM 66 nine years ago and occasionly it would kick out the breaker on startup.
The mickey mouse electrical supply in Salina didn't stock a time delay breaker for that supply panel , so I installed a 25 amp breaker and the trouble went away.
The Motor is a Baldor which is a good brand of motor and after talking to a couple of electrican friends , they said it is not unusal for a motor of that size nowadays to need a 30 amp service.
That machine out of all of the 220/20amp served machines in the shop was the newest and the only one to kick out a 20 amp breaker.
FredD
