OT: PC Register Cleaners????
Jesper, Denmark
Jesper, Denmark
>I am confused. Do these various programs really work? Are they necessary?
I am somewhat ticked off - they all say "Free" on their websites, and then tell ypou they have found 16032 errors, of which they have cleaned up (from 2 to 50), but if you pay $29.95, they will activate the whole program and clean it all!
Scanning and running the same program again, the number of werrors found are the same as before they removed X number of errors. My poor logic concludes trhey di nothing.
FYI, I am running Vista Business on an HP Compac with Intel DuoCore processor around 1.8 Ghertz with 2 gigabyte RAM. The hard drive seeems always to be busy doing something. I run AVG fully paid antivirus and connect to the netthrough a router with firewall.
Re: OT: PC Register Cleaners????
Alex Grigoriev
>Look up "snake oil" meaning in the dictionary. This is what the registry cleaners really are.
Jesper, Denmark
Jesper, Denmark
>I was afraid of that.
Jim Dillon
>Jesper,
LOL! Only 16032 errors?? You should try some of the "free" software that guarantees your internet speed will increase 500% if you only use their software to "adjust" your computer. I've never had the courage to allow one of those to work on my computer, let alone a registry "fixer". I know some of them say they will back up your original settings, but like I said, it's not for me. While I use CCleaner to clean things up (and it has worked just fine for that), I do not use its registry fixer component. No guts I guess 8-).
Jim
Re: OT: PC Register Cleaners???? *LINK*
JimG
>I've used Registry Cleaners since Norton came out with System Doctor for Win95. I'm an IT professional. I use them after fresh installs and they always find about 200-300 errors. They can speed up a slow system and fix one that crashes. However, I research the ones I use first, making sure they are legit. Here is a link to a free one that works well. This one will not run automatically. I would run it at least once a month.
jim
http://www.eusing.com/free_registry_cleaner/registry_cleaner.htm
Curt Harms
>I use this:
http://www.amazon.com/Avanquest-1661-Fix-It-Utilities-Professional/dp/B000V7V2UE/ref=pd_bbs_sr_1?ie=UTF8&s=software&qid=1216858388&sr=8-1
I don't use the antivirus component, just deselect that when installing. It has a good hard drive maintenance component and a good cleanup function-registry, duplicate files, dead shortcuts etc.
Jim Dillon
>JimG,
Well, I screwed up my courage, downloaded your suggested free software, and - holding my breath - turned it loose. I backed up first, then took it step-by-step checking some critical programs along the way. So far, everything is still working. I like the way the program allows one to select the different areas to scan. It appears to to be quite similar to the registry cleaner component of CCleaner - which I had never used. Thanks for the recommendation!
Jim
