>Wanting to add a dust collector to my shop and primarily to use with my wood lathe. I want something that will pick up as much dust as it can and am not worried about not getting the shavings as the dust from turning and sanding is what I am most after,
What cfm do I need for that, or is it possible that this will not work and if not what do I need to get.
Never used one so someone that uses one for this purpose please fill me in.
a)Use a Cyclone Lid since turning makes a lot of chips and you don't want to clean up your D.C. bag too often - see the link below for the kind of lids I'm talking about. They're available from many woodworking / catalog stores such as Woodcraft, Lee Valley, etc.
b)Use or make yourself a dust hood to collect dust and chips from behind the lathe. (Here's is how one turner uses a shop-made dust hood for his lathe. Or you can buy one for may be $30 - $40.)
550 - 600 cfm is good enough for the kind of chips generated by turning.
>Post this question on the Turning Forum (Message boards, to the left, Turning) to get mroe answers.
I have a DC in my shop and have never set it up fo the lathe because I am skeptical it would do much good. At least in catching the chips. I do mostly bowl turning and those chips fly everywhere. For sanding, I bring up the hose from the DC and attach it to the tool rest. Works well.
Be aware the the sawdust packs into the pores in the filter and slows the airflow dramatically. It might cut the volume in half. So start out with excessive volume and let it decrease. Does nto take long. An hour or two.
The separator if an excellent idea for the big chips. I vac-ed up a bunch of long curls with my DC and noticed it sounded funny. Looked in the impellor and it was full of curls. Not good to run stringy trash through the impellor.
Also bear in mind that the DC does not really cure or ellimanate the problem, it just moves it. Cleaning the filter or filer bag is a dusty job and may expose you to the very dust you wanted to ellimante. And then there is the emptying of the bin. Wear your personal Protechtive Equipment.
