bandsaw tension
Jeff Weaver
>I have a Grizzly G0555 14" bandsaw. Today I installed a Carter tensioning spring. I noticed right out of the box that the Carter spring is about 3/4" shorter than the factory spring. Sure enough, when I crank the handle to engage the tension spring, the tension indicator shows to be at the proper tension for a 1/4" blade and I can still slide the blade off the wheels with my fingers. Obviously, I will not be able to rely on the gauge with the new spring. So how do I know if I'm getting the proper tension and actually getting good use out of my new spring? And what is the danger of over-tensioning? Can I damage the saw? Or have I just goofed up on installation?
Thanks in advance,
Jeff Weaver
