spacing for cabinets
John Hoffman
>Hi guys,
I am making a set of book cases for a friend and they have to fit between two walls. The space is 130". What total size would you make the cabinets so they fit with ease into the space and allow a scribe of the face frame to the wall? Would an inch be enough?
Thanks
John
Re: spacing for cabinets
Bob Lang
>Hi John,
It all depends on the condition of the walls, where the cabinets will touch them when the cabinets are complete. Do some surveying work before you start, measure the wall at the floor, ceiling and in between and retake the measurements out from the wall, where the face of the cabinets will be. Bring a framing square and level with you and look at the corners and the condition of the walls.Also check the levelness of the floor and variations in floor to ceiling height. In order to make the cabinets well, you really need to know the hole they will be fitting in.
In theory, the amount of scribe you need will be the amount that the wall varies from a straight plumb line on each side. In reality, you'll need more than that, but not too much-you don't want to end up with a skinny stile on one or both ends. For that distance, it sounds to me like four cabinets. When you install, plan on setting the ends, scribing them to the wall so that they are level. Then you'll need to take some more material off so you leave yourself the exact width of the other two cabinets.
I'd think about building them with an inch or so of stile on the outside of the cabinet box, and the total overall width about half an inch longer than you think you need, unless the walls are really bad.
hope this helps,
Bob Lang
John Hoffman
>Thanks it does help.
Will do as you said.
JH
