OT - Saw to trim Granite Stair Treads
howard
>I need to cut some 2" thick granite treads that will be used for steps. It's not much - is there a hand saw that I can use with a diamond blade that can then be used in the woodshop. Don't see the point to rent when the purchase cost probably is not that much more if I can get further use from it. Appreciate your suggestions.
Re: OT - Saw to trim Granite Stair Treads
Gerry Wittenberg
>Check with Chico, he has a WWII blade that Sophie test ran for him using granite.......
Gerry, with tongue firmly in cheek
allen heath
>if you have a milwaukee sawzall, or any reciprocating saw that takes the same type of blade, milwaukee makes a masonary cutting blade...i have used it successfully of brick, mortar, and cement....it might work on granite too...they are about ten dollars each....much cheaper than buying a wet saw
>You might check with a local kitchen countertop supplier and see if they would trim the pieces for you. Mine told me I could bring back offcuts and they would trim them to size.
you can use a dry cut diamond blade
John in New Mexico
>They're available for circular saws and angle grinders, it'd be kinda rough going on granite, but should work fine. For just a few cuts you can use a cheapo like from Harbor Freight, but I've found they only last about 25% as long for half the price of a quality blade (thats still a long time - I used up three building a stone stem wall for a 1500 sq foot house). I usually buy them at HD or Lowes.
Thanks All
howard
