OT.Re-Glazing Question
Sawman
>I am going to replace the glass with insulated glass in some Pella windows.I will need to remove,hopefully with out breaking, the exsisting glass. Any thoughts as to what to use?
Sawman
Re: OT.Re-Glazing Question
George Koch
>The Pella doublehung windows I have cannot be reglazed without disassembling the wood sash, and to replace with insulated glass would have to be remilled to accept the thicker glazing. George
Glass Shop
Dustmaker Mike
>I am brining a sash a month to a glass shop to have them redo my pains. The windows are all double pain but are ~15 years old. They have a really nice wood trim inside so I don't want to replace them. I found a few subcontractors I know and asked where to get the windows. I will get the pricing then. So to answer your question I would find a Good Glass shop and see what they say or how much they would charge to do it for you.
Are they double pain? Or single pain? will make a difference also
Re: Glass Shop
Sawman
>The windows I am going to do are fixed in place so they cannot be taken to a shop. I will be replacing the single glazing with a insulated panel. I have already milled the new stops.
So the only question I have is what is the best way to remove the glazing that is already in place?
A little DAP will do it
Dustmaker Mike
>then I would use the DAP 33 window glazing compound. Keep in mind I am not a glass worker and I do not play one on TV but I did stay at a Holiday Inn Express last night(-;
Kneale Brownson dreaming of snow in N. MI
>Is the existing glazing done with a glazing material or with some form of adhesive/plastic? If it looks like a glazing material, a putty knife might be the tool of choice. If it looks like an adhesive seal, something like a carpet layer's knife might be better.
Wayne Carson "TX"
>If the glass is put in with glazing compound heat it with a heat gun a little and it will soften the compound. If with stops just be careful and score around the stop prior to trying to remove and it probably wouldn't hurt to still use the heat gun as they usually use an adhesive when they put the glass in to seal around the unit.
Sawman
>I spoke with Pella Parts/Service today. They said use a Fein Mutimaster with a flexible blade. Since I have the Fein Tool I ordered the blades from Amazon and I should be good to go.
