PB router table top: Hosed it...
Dan Mitchell
>So I glued up my $0.51 3/4" UL particle board router table top yesterday. Squared the edges today. Looked perfect, about 24 x 30, 1 1/2" thick, just right. Then I laid it flat on the TS. Cupped. Mid point on the 24" axis is about 1/16 off the table. It's not like I didn't KNOW about checking this before gluing. It's not like I didn't KNOW about putting both sheets crown-in so they cancel each other's warp. I just didn't think to DO IT (unlike the unseen hand of fate, which DID remember to NOT have the sheets just HAPPEN to go together the right way... ;-)
So, in the absence of a 24" planer (don't got one), I'm guessing there's no way to flatten this puppy, right?
At least I'm only out $0.51....
Dan
Re: PB router table top: Hosed it...
Jim Dillon
>Dan,
Hey, nothing ventured, nothing gained - right? Don't know how you were intending to fasten the top to your router table, but some sort of edge-on bracing underneath the top with pocket holes might be able to pull the top snug - thus flat. Being able to also glue the bracing to the underside of the top would be even better but I remember you were thinking about laminating both sides. What about laminating just the top side and not the bottom, or the bottom just in areas where there is no bracing. Hope this makes sense. Don't give up quite yet.
Jim
Chuck in ND
>If you put the crown up your going to cut a pretty good size hole in the top for a router plate I assume, and if your router has any wieght to it, that maybe just enough to bring it down to flat. The crown just might actually be a blessing in disguise.
>Good Afternoon Dan,
Good info above for sure. If I were you I would invest in a couple straight cleats and pull the crown down into flatness with countersunk screws in the particle board. Check for flatness. If flat, then apply the laminate over the countersunk screw heads. Then you could apply laminate to the underside as necessary/desired. You could substitute flat headed threaded bolts going all the way thru the cleats and secured with flat washer, lock washer, and retaining nut. Fill any void above the countersink and level before applying laminate. Properly positioned, the cleats won't cost you much room under the table. Be sure not to crowd your router adjustment accessability.
George
paul waddle
>Iwy,I'd keep that board for something else. The suggested fixes 'might' work,but I believe you'll have a better mind set if you just go to another glu up. This way you can concentrate on getting everything else right. There will be this continual nag-is it straight now. You COULD make a ts cut on the crown and I'm sure pull it down,but the idea is to make a top,not fiddle correcting a mistake. pw
Jim Dillon
>Dan,
IF you decide to use screws from the underside, I would suggest clamping the top first to any underside bracing to actually draw the top flat (rather than relying only on the screws). Then apply multiple screws through pocket holes/cleats etc. Naturally, if you also use glue (highly recommended), let the glue dry overnight before releasing the clamps. If you don't have any expensive deep-throat clamps, then using some cauls (left-over 2x4s on edge, for example) should work. If you work from the top with either screws or bolts (as George suggested), then they should be able to draw the top flat without clamping. And Paul's suggestion is valid as well. Chalk it up to experience and move on to a nice flat piece of plywood or MDF. Hope this helps.
Jim
pecker
>I made one similarly about 5 years ago. It had a crown of only .01" from front to back. Even with a Makita 3612 router hanging in it all that time, it hasn't sagged back to flat. I make do with it, but I don't think I could live with .06" out of flat.
Dan Mitchell
>Mostly out of curiosity, I've rigged up some clamps & lumber to flex the PB backward against the depression approximately the same degree as the warp. I.E., not flat, but now warped the opposite direction. Figured I'd leave it like that a few days, then see what it looks like when released. If nothing else, I can probably use the some of the 1.5" thick PB as part of the fence.
Could probably flatten the PB with cleats, but I agree, the best thing would probably be to get some nice birch plywood for the top. Not that it's immune from distortions; if anything, MDF/PB may be FLATTER. With all this stuff, how it was stored seems to be a major determinant.
I wonder if anyone has ever used OSB for this? Never worked with that material. What are its tendencies, regarding flatness?
Thanks for the replies
Dan
>Good Acftgernoon Dan,
I believe you have made a good decision regarding the birch ply. I've used it in numerous applications in and out of the shop, and was not disappointed. Alas, my router table top is of bpwling alley maple. I edge glued solid cherry stock and it looks great. OSB I never use for anything.
George
OSB is OK
Tom Pilsbury (Chicago)
>I recently completed my first router table built with mostly OSB. With the help of the good folks here at WC, Bill Hylton's "Router Magic",American Woodworker #24, and a little luck I managed to produce what I consider my most ambitious project so far. It was my first attempt at making drawer lock joints, installing drawer slides, mounting the router base plate, and wiring the safety switches. I also built the adjustable fence from Router Magic. It looks pretty good and works fine for me. But I'm just a hobbiest and not concerned with minute tolerances so YMMV. Here are some pics.
The base cabinet:
With the top
>Top is made from a sandwich of 1 sheet of particle board and 1 sheet of MDO plywood. Edge banded with poplar and finished with about 6 coats of water based poly.
Finished project
>Once it's painted you cant tell it's just cheapo OSB. And the red knobs are from old kitchen cabinets. I knew they'd come in handy someday. LOL
Re: OSB is OK
Jim Dillon
>Tom,
Nice job Tom! I think sometimes we can get carried away with "perfection" regarding the materials we use. While I would never likely use OSB or particleboard for woodworking projects, your successful project is a perfect example of why I am wrong and you are right!! 8-). Thanks for posting.
Jim
Sounds nicer than our FURNITURE!!! ;-)
Dan Mitchell
Looks great Tom
Dan Mitchell
>What are you using for a fence?
Re: Looks great Tom
>Dan: I made a fence from the leftover MDO and some MDF. Sorry no pic. It looks just like the one in Router Magic.
Re: OSB is OK
>Thanks for the ego boost, Jim. While striving for perfection can be a good thing I do realize my limitations. With practice and experience I'm sure my woodworking will improve enough to use the more expensive or exotic materials on the first try. In the meantime I'm enjoying my hobby without breaking the bank.
Re: OSB is OK
>OSB? I am working on a house and using OSB for the roof sheeting and lots fo other things. I have used it in some shop projects. The sheeting grade material is rough in more ways than one. One side has a sort of screen texture to give you footing on the roof and the other side is not sanded. I have not checked it, but I am sure the thickness varies a lot, probably several hundredths.
Also, don't get it wet. What we had was 7/16" and the H-clips for the edges were half inch. Very loose, until the rain came. The stack got wet in about a ten minute rain and the H-clips are now snug.
And be prepared for splinters and splintering. Oh!, and "flat" has nothing to do with it. Not even in the vocabualry of describing OSB. It is flexble and easy to flatten, but if you are counting on it being flat, fagedaboudit.
