Re: Ammonia ...
Al Stokka - Cambridge, Iowa
>Joe,
I had a problem with fisheyes in an oil-based polyurethane finish. Michael Dresdner offered the following information, Mid-April, 2007:
The solvent for silicone oil is mineral spirits. Scrub contaminated raw wood with liberal amounts of mineral spirits and sop up as much as possible (don't just spread it around.) Follow that with a scrub of liberal amounts of warm water laced with household ammonia, which is a surfactant for silicone oil. Again, mop up as much as possible. This one-two punch will remove the lion's share of the silicone oil.
I followed his advice and while it worked, I didn't not strip the previously applied coats of poly. Therefore I had to deal with the divots in the previous poly finish. Many rounds of sanding to smooth without cutting through the finish and applying additional coats of poly. If I had to do it again, I think I'd strip the finish and start anew.
Good luck,
Al
