CEDAR COOKING BOARD
CEDAR COOKING BOARD
CEDAR COOKING BOARD
CARL BARTON
>Recently a freind asked me if I could make him a cedar cooking board that could be used on a grill. So I started looking around and found one at store that is used to cook salmon. The board must be soaked in water 3-4 hours prior to use, then you throw it on the grill and place the salmon on the plank.
My freind knows I am a wood worker and asked if I could make him one of these and would it be safe to use. It would be cheaper for me to make him one vice buying one.
My question is would the board I buy(at a lumber store such as Woodcraft) and cut to size for someone's use be safe to use, vice buying the one at the store advertized for this sort of use? A 6 x 12 board cost about $35 and I have some cedar just laying around the shop I could give my friend.
Carl
Re: CEDAR COOKING BOARD
Howard Norman
>I use cedar fence boards purchased from Lowe's for plank cooking like your friend want to do. All that I have ever done is run the board thru the planer or the jointer, which ever is convinect, to get one surface flat and cut it off. Nothing fancy needed at all.
Re: CEDAR COOKING BOARD------WebKitFormBoundaryFu+
Keith Newton, LR, Arkansas------WebKitFormBoundary
>I hope your friend know that the board doesn't go right over the flame, or the board will burn up before the fish cooks.
I have a friend who introduced me to this method. He kept a bundle of cedar shingles around for this, and kindling to start the fire in his fireplace. I went up to visit once, and they had gotten everything ready to cook, when he found there were no more shingles. I took my chain-saw out and cut a plank out of the stump of a eastern redcedar stump "juniperus Virginiana".
While it was cooking, the aroma was so wonderful that we were all just giddy with anticipation to try it. We all agreed that this was better than the other. Now having said that, I am sure there will be some wondering whether this is safe. My thoughts are, I doubt it.
Both of these kinds of wood have great resistance to decay and insects and other vermin. I have a piece of the E red-cedar here in my office that I found, which has 500 annual rings on it that I found about twenty something years ago. It had been injured by fire about 400 years before it died, exposing half of its girth to the elements. Any kind of wood that can be exposed to the elements in Ar. without rotting for that long could not possibly be good for human consumption.
However, If you try it and it does kill you, you probably will die happy.
------WebKitFormBoundaryFu+uhh6L+xN6Xn42
Rob Stokes in North Vancouver
>Just use a fence board (red cedar). the 5' ones are usually cheapest and one of those will yield 6 planks. I plane them (full length) just to get rid of the fuzz that invites flames. I also knock off the sharp edges - again, to try and reduce the potential for flames. Then I soak them overnight (placed on-end in a 5 gallon bucket, weigh them down with bricks).
There's something strangely satisfying in beginning dinner preparations in the shop :).
When it comes time to use them I bring the BBQ up on low and put the planks on the grill, "fish side" down. I warm them (get the HOT), trying not to char them too deeply as deep charring reduced the plank's ability to pass heat to the underside of the fish. . When they're hot, turn them over add fish, make sure there's separation between the planks, turn up the heat, close the lid. And whatever you do - don't open the lid again! That cedar is going to smoke like you've never seen smoke before, but if your BBQ is even close to airtight, there won't be a lot of flame. That'll change the instant you open the lid, so be prepared with a squirt bottle full of water.
When done (10 - 15 mins) Take the fish off the plank and onto a platter, and drop the board into the same 5-gallon pail to extinguish it. Repeat for as many as you have.
Rob
Planks are only used once (at my house). And there's no taste like salmon cooked that way.
Rob
Kneale Brownson dreaming of snow in N. MI
>Now I understand why my buddy who was showing off this technique ended up with a badly charred board and half-raw fish. He couldn't leave the lid down! It wasn't delectable by any means, and I could not understand the attraction to this method.
CARL BARTON
>My many thanks to all. My wife was visiting her family in WI last month and found one of these boards at the dollar store. She knows I LOVE salmon and bought it. Then yesterday my freind asked me about using one of these boards and I told him I had one, but had never cooked with one. I told him I knew I would be able to find the anwser here, so now I think I am going to try out my salmon steak tis Friday night when my wife has to teach. She does not like fish so Friday nights are my nights to try new cooking ideas.
I retire from the Navy this coming Decemeber and the wife keeps telling me she is going to send me to cooking school so I can cook all our meals. :) I do not mind, after 33 years in the Navy I am looking forward to a much slower pace, cooking and LOTS of wood working.
Once again thank you all for providing me the information.
Carl
I have a great....
>recipe for Planked Carp that uses exterior grade plywood over a CCF pressure treated yellow pine fire.
Clint
Dick Coers
>I think we should claify that the red cedar should be Western Red Cedar. Or white, or yellow, just not aromatic red. Here's a quote from one of the guys on The Forestry Fourm;
Let's see, Cedar. DON'T USE RED AROMATIC CEDAR. Too much oil and will make yer food taste bitter. I sell Brown?? cedar. Don'T know the actual name. I'm sure White cedar will work, also.
My buyer tells me that he soaked them overnight. I believe he changed that method to; soak them for a couple hours. He puts them in water with that Woosterchester stuff mixed in. Puts the Salmon fillet on the board, with seasoning added, and puts it in the broiler or oven, till the fish is done.
I have heard that Alder works well. Soak yer wood overnight and then put it on the grill or Barby and cook yer meat on the board. You are actually steaming the meat.
Why not use Cedar shingles???
Terry Quiram, Roanoke Illinois
Use Alder instead
Gary Camp, Bend, oregon
>Or at least also. I prefer Alder planked fish myself. The place Lisa works has palder planked Salmon on their menu, it is much better than the Cedar planked Salmon I've done. Red and pink meated fishes seem to pick up the smokey flavor better the than white meated fish. Halibut is good planked but Pacific Salmon is GREAT. Cedar shingles may be treated with fire retardent.
glc
