ebonizing
ebonizing
ebonizing
McKay
>I have ebonized before, but I can not remember how long steel wool and vinegar must steep before you can ebonize wood. Does anyone know? Thanks in advance.
Re: ebonizing
Re: ebonizing
Alex Grigoriev
>Depends on steel wool number. Use the finest. You may also want to wash it in a solvent, to remove any protective oil, and tear it to small pieces.
According to my calculations, you need about 2.5 g of iron per 100 g of 5% distilled vinegar. When it's fully dissolved, almost all acetic acid reacted, no more iron will react.
Re: ebonizing
Re: ebonizing
John McGaw
>I've always found it easier and more reliable to use leather dye. The chemical reaction involved in the steel wool/vinegar solution seems to be far too dependent upon the amount of tannin in the wood and I've never gotten really good black -- even freshly cut red oak never seemed to get more than dark brown for me. Black leather dye really does give the black seen in Gabon ebony.
Re: ebonizing
How about...
>lamp black pigment paste, Ronin brand. Can't get much blacker than that. Just thin as much as you want with naptha, rub it in, and finish with anything.
Clint
Re: ebonizing
Re: ebonizing
Craig in Silverdale
>I've had good results with India Ink before. Not expensive and readily available at art supply stores. Good luck and have fun.
Re: ebonizing
Re: ebonizing
Fred Davis
>I used Omega leather dye for years on leather , then wood and found out from a leather worker guy by the name of Al Stolhman that if you dyed it dark blue first , then the Black was a true Black without any of the purplish undertones in it.
FredD
