200+ woodworking book reviews
OT Snowblower!!
OT Snowblower!!
OT Snowblower!!
Sawman
>I know it is only July but I am doing some maintenace on my sb. I am taking it apart to snadblast it and repaint it. It is an old John Deere and the new ones just don't cut it. My question is one of the augers is really rusted to the shaft so that the shear pin means 0. I put PD Blaster in it yesterday and it is still sitting there it does not seem to have gone down.
What can I use. If a torch all I have is propane.
Re: OT Snowblower!!
Hot and cold
Dustmaker Mike
>you can try and heat it up then toss ice cold water on it. Caution the PB Blaster is flammable so be cautious with the torch. I would let it soak and bang it with a dead blow hammer. It will come off. Or take the auger out and bring it to a machine shop or a place with a press and have them put a press to it. Another way could be if you can get the auger all the way out and stand it on end then use the PB Blaster so it goes down the shaft and then the dead blow hammer. Just a few quick thoughts. Good Luck
Re: OT Snowblower!!
Re: OT Snowblower!!
Bob Persing
>I think you could give a try with your propane torch. The idea would be to try and heat the sleeve of the auger without getting the inner shaft too hot. The idea is to expand the augers sleeve and not the inner drive shaft to try and break the bond between the two. Even if this does not solve the problem immediately, it just might help get some more of the blaster down, inside, where it can do its work. Let it cool down and add more blaster. I would keep the heat away from the augers gear box, perhaps wrap it with a soaking wet towel when using the propane torch. You may want to consider the purchase of a Mapp torch. They are great for heating things real fast and you can also do brazing with the mapp. I got a mapp "kit" at HD for about $30 and it included two mapp tanks. Getting the outer sleeve hot fast is going to help you from getting the inner shaft too hot at the same time.
Good luck. It is great that you are "re-cycling" your JD!!
BobP
Re: OT Snowblower!!
Re: OT Snowblower!!
Kneale Brownson dreaming of snow in N. MI
>Try a 50-50 mix of automatic transmission fluid and Acetone. Penetrates better than PB Blaster.
