steam bending bowed arm Morris Chairs
mike@american sycamore
>I have the Delta team here this week at American Sycamore and we are building eight bowed arm Morris chairs. We are steam bendng the
1 1/8" x 6" x 42" quarter-sawn white oak arms. Thanks for the tips I got here at WoodCentral I buit a steam box from 3/4" Marine grade plywood. I covered the outside of the box with 1" stroyfoam.
I bought two new 5 gallon heavy duty gas cans and with a propane industrial torch under the filled with water gas cams I boil the water. I have two hoses going into the botom of the box from the cans. Using a meat thermomitor we bring up the heat to 220 degrees then load four pieces of wood and heat for 70 plus minutes.
We have found that you have to work quickley because when you open the door the heat drops quickley. We load the arm pieces on a form and clamp down while one student stands on the board bringing it down to the curve and then clamped in place to dry over night. So far we are batting 100% with 12 arms bent. It is so cool seeing that wood bend into shape.
I am looking for a way to build a steam box that I can heat with an electric commercial hot plate so I can bend in doors at shows. If anyone knows of a source for a used commercial hot plate that will boil water for 70 plus minutes on a commercial scale please let me know. Thanks,
Mike
