Question on paint sprayers
Robert R Clough - Thorncraft
>I am interested in picking up a decent paint sprayer which will also do polyurethane. I do not want an expensive compressor/sprayer - I have an old, decrepit (40 YO) tank compressor now underpowered which works for tires and do not wish to upgrade.
I have seen/read about Wagner and am unimpressed. The comments seem decidedly unfriendly. I know nothing about the Black and Decker equivalent.
In other words, I want something which will do latex paint and polyurethane - thick and thin - and inexpensive.
Any suggestions?
Re: Question on paint sprayers
If you're located in the US
Howard In Toronto
>the earlex HVLP spray units seem to get good reviews.
HTH
Howard
Re: If you're located in the US
>Howard, yes I live in Muskego, WI. However I can find no Google match for eartex. Is that the correct name? (And Seartex also is nonexistent.)
Chicago Bob
>both Woodcraft & Harbor Freight stock this sprayer
regards
Bob Haines
earlex not eartex
tek-Brunswick, Ohio
yes - earlex - sorry for the typo
Howard In Toronto
Earlex HVLP *LINK*
David Yoho
>Bob, if you would like more info on this sprayer, check out the video by Charles Neil in the link below. It may answer some of your questions.
David
Earlex HVLP Review
my opinion of Earlex
Michael Dresdner
>I did a major article for WWJ comparing various HVLP self contained rigs. Earlex was tested but not included because it did not fit within the parameters of the article. However, based on the results I saw, I wrote a piece for the WWJ eZine about the Earlex unit.
Simply put, for the money, you won't find a better self contained unit. It plugs into a wall socket, has a carry handle, a place for the gun to sit, and sprays everything but heavy latex paint easily and well. At the time of the article it ran about $250.
On the other hand, if you have a compressor, no matter how small, you can run a standard (non HVLP) spray gun on it. Choose a gun with a fairly small maximum fan width (six inch would be ideal) and not some monster with a two foot fan. A small fan gun will require very little cfm and fairly low psi, yet will still spray anything. You can pick up Chinese knockoff guns for under fifty dollars, if that is your inclination, or a well made gun backed by company support for twice or three times that.
Thanks Michael!
Tony - Memphis
>Your input is always appreciated here. I looked at the Earlex before and I recall your article. I've never sprayed anything, but there have been several projects where I wish I had something other than a rag or a brush! Recently, the huge side of a dresser. Hard to not leave any marks on a large surface like that. Sounds like the Earlex would be very handy.
When you mention the latex, does that mean no latex, or just that you'd need to thin it?
Thanks,
Tony
Re: Thanks Michael!
Joseph Mulherin, Sr
>Tony, I posted something earlier on spraying latex. Basically you do have to thin the latex to use in a siphon-type spray gun.
Take a gallon of latex, mix in one(1) quart of water, stir until you get a consistent thickness through out the gallon. I generally use two pain cans for this. I have sprayed my house four times using my spray gun this way...on the eaves it works nice too...
While spraying I suggest wearing cloth gloves....why?...because the nozzle sort of gets clogged after a period of time and you just wipe with your finger and keep on spraying.
Hope this explains about the latex spraying problem.
earlex and latex *LINK*
charlesneil
>the earlex will spray latex they have a 2.5 needle/nozzel that you will need to use..it comes with a 2.0 unless you buy it at Woodcraft then it also has a 1.5 the 1.5 does well for waterbased and solvent based finishes..the 1.0 is beat suited for waterbase..1.0 is not typically suggested for waterbase.however the smaller orifice helps the atomization..just open the fluid needle wide open...but the 2.0 will also spray it in the test I did I had to thin the latex about 5%, the 2.5 sprayed fine...it only has a 13" hose, so those eves of Michaels might be a bit tricky.
http://www.antiquesbuiltdaily.com/tips.htm
Thanks
Tony - Memphis
>I may just have to check this unit out. I asked about the latex because I thought it would be nice for a few projects around the house. Thanks for the information. Much appreciated.
I almost bought a psrayer when my house needed painting, but the guy that painted it gave us a quote that was too good to pass up and he was done in a day and half or so. Did a great job too. I hate to pay people to do stuff I can do myself, but it was sure nice to come home and it be all done. Never even saw the guy.
Thanks for the videos too Charles.
Tony
