Handplane Refurb Question
Jerry Samsen
>I'm new to handplanes but have owned a small block plane for some time and found it very handy. I wanted to try other planes but investing in an expensive Lie-Nielsen or equivalent was too much and buying an el cheapo may be a mistake. So I bought a Stanley No5 Jack plan on eBay ($30) to referb and tune.
I noticed in my new, used plane that there was a small area on the base where the cast iron looked unusual almost like it had significant corrosion and someone tried to grind it off.
First step was lapping so I started lapping using some paraffin oil and Veritas lapping grit (started with lowest grit - 90) on a 1/4" plate glass. After grinding for considerable time I noticed that the suspect area was not touched by the grinding. I cleaned and placed a straight edge along the base and noticed that there was a gap in that area. I can't say how much (0.01"?) but seemed like enough that hand lapping would not work.
This area is about 2/3 of the way from the mouth to the back of the plane and offset to one side of the base in a area about the size of a nickle.
Would this small imperfection in the base cause problems? If so, I'll dump this one and look for another. I'm sure with the right tools this could be reground flat but the investment may not make sense. I don't have any tools (like a edge sander) to do aggressive power grinding / sanding.
Thanks.
