Installing Shelix Head for Delta 37-380 Jointer
David Yoho
>I had several requests to document replacement of the original three-knife cutterhead on my eight-inch Delta model 37-380 jointer with the new Byrd Shelix cutterhead I purchased from Sunhill Machinery.
The process is fairly simple but there are three documents that I found helpful for removal and installation. The instruction manual that comes with the jointer has all the adjustment and assembly information you'll need. The Delta parts breakdown list is also helpful for identifying parts and where they go. The final document is the Sunhill Cutterhead Installation PDF File from Sunhill's Website, which I printed and took to the shop.
I started by unplugging the jointer, disconnecting the four-inch dust collection hose, removing the rear cover and V-belt. Then I used the allen wrenches supplied with my jointer to remove the allen head bolts to all the assemblies and brackets to allow access to the end caps of the old cutterhead. The PDF file shows a good diagram of the old cutterhead and how to remove it.
With the cutterhead removed, this is how things looked:
Here's what's in the box from Byrd Tools - a Torx bit, screwdriver handle, five extra carbide inserts, and instructions for insert removal/rotation. It also came with the bearings already installed on the cutterhead shaft.
Here's a shot of the original head, the Byrd head, and the printed PDF installation instructions.
These are the left and right supports/end caps cleaned and ready to go.
The supports/end caps slipped right over the respective bearings and are now ready to drop back into place.
The hex nuts and washers (one on each side) for the support studs are ready to be tightened.
After checking that the cutterhead was level with the outfeed table on both sides, I tightened the hex nuts. The instructions say to shim if necessary. You can use a block of wood when checking for level but I used my Lee Valley straightedge. It turned out that mine was level and did not need shimming. This is an important step because, unlike the standard cutterhead, the inserts of the Shelix head are not adjustable up and down, so it's very important that the head be level with the table.
Next, I installed the pulley by placing the key into the shaft's keyway and tapped the pulley onto the shaft, being careful to align it with lower pulley, and then tightened the two allen screws.
I re-installed the section of the infeed table that the blade guard mounts to. Alignment is facilitated by two pins. I used a soft-faced hammer to tap the assembly on before installing the allen bolts. I put a little blue Locktite on the threads before installing them because originally they had some on them when I removed the bolts.
I followed the same procedure for installing the cutterhead pulley guard/carriage bracket.
I mounted the fence carriage assembly to the cutterhead pulley guard/carriage bracket next.
Finally, I attached the fence to the fence carriage assembly and installed the blade guard and adjusted the spring tension so the guard would return properly. At this point all that is left to do is to put the rear cover back on, attach the dust collection hose and clamp it, and plug in the jointer's power cord.
I adjusted the infeed table height where I wanted it and the outfeed table just a little. I then turned on the jointer and tested the outfeed height adjustment to the cutterhead by running a piece of stock on its edge. I got a little snipe on the trailing edge on the first few passes. I kept adjusting the outfeed table height until this disappeared completely.
With the adjustments made, I ran a piece of aromatic cedar with a big knot on one part of the edge across the jointer. Normally my old cutterhead would tear or take chunks out of knots like this. The Shelix head cut it like butter and left it smooth and defect-free.
Now it was time for the real test - a piece of highly figured tiger (curly) maple. I ran one face first, then an edge. There was absolutely zero tear-out anywhere and the cuts were super smooth. The finished surfaces looked just like they do after using a hand plane or scraper on wood. The surfaces had that just-planed sheen to them that made the figure jump.
While the Byrd Shelix head is a bit pricey, I did get it at a $60 discount from Sunhill, which saved a bit of money. However, after seeing the results I got, I think it would have been worth every penny at full price. I have to say this cutterhead performs as advertised and it's one of the best upgrades I've made in my shop in a long time.
David
