Pair of cabinets
Pair of cabinets
Pair of cabinets
Thomas S Stockton
>HI all,
Some of you may remember the post I did about a pie pattern top that had moved before I had time to veneer it down, here are the finished cabinets. They are curly maple veneer and a solid maple border around the top. The client approached a gallery I show in about building something similar to a picture see had from a design catalog. The cabinets were elliptical but were rather plain and were not as nice as they could be.
My job was to take the basic idea and make a pair of cabinets that were much nicer and much better built. Each cabinet has a door and slide out writing surface on touch latches. The gaps around the door were left wider than usual as a homage to the originals which were monstrous and fairly ugly, it also gives it a more sleek look and accents the door.
The tops are a 12 way pie match, that turned out really nice, it was originally speced out as an 8 way, but you get a nicer look and more visual movement with a 12 way.
Tom
Re: Pair of cabinets
WOW!!
doug f, san clemente, ca
>I haven't seen that level of craftsmanship in a long, long time and I look at a lot of cabinetry.
I'd love to see some shots of the inside and details of hinges, latches, etc.
Outstanding work.
Doug
Holy Moley!!
Howard In Toronto
>Beautiful work.
Thank you for posting these photos.
BUT....
we need more.
More photos.
More design/construction/engineering details.
More ewverything.
Thank you!
Howard
Beautiful!
Tony - Memphis
Striking !
Yonak
Wowsa!
>Tom,
Home run man! Wonderful veneer work and the design is cool. I really like those!
Tom
Alan Young
Drum ditty ditty dumbfounded!
Alan Young
>Can't beat those with a stick! Great looking cabinets Tom.
Very fun. Would love to see operating details.
Alan
Re: WOW!!
Thomas S Stockton
>Doug
The door is hinged with a pair of butt hinges and the touch latch is a standard issue magnetic touch latch. I've never found anybody that makes a really nice furniture quality touch latch so I don't use them much but when a client request them I will, the ones on this cabinet are made by Sugastone and are OK quality but still are a chunk of plastic.
Tom
Re: how did you???
McKay
>How did you do the stave joints around the top? Are they biscuited, tenoned?
Re: how did you???
Thomas S Stockton
>Bent the sides on a form in a vacuum press. The core was bending luan(wiggle board) and a couple of layers of bending poplar and are attached to the legs with biscuts.
>Good Afternoon Tom,
Those really are extraordinary. I'd never have the patience. I'm sure you are more than pleased with your achievement.
George
Oh my!
Joanne Adler in Pt. Pleasant, PA
>These are spectacular! These are fine, indeed. I'll bet you even exceeded your client's and your own expectations. Well done!
Dale Lenz
Re: WOW!!
Dale Lenz
>Beautiful piece of work, for sure! If you Google "brass touch latch*" you will find a few brass touch latches.
