HVLP question
HVLP question
HVLP question
Theresa
>I was wondering how long a Waterbased Poly can be in the HVLP gravity gun. Do I have to clean it every time between coats? That would be a hassle, but I would if I have to.
Thanks in advance for any advice.
Re: HVLP question
Re: HVLP question
Ed Mulligan, Cape Cod
>I clean at the end of the day. I might have sprayed a dozen or more coats on various items during the day. I'd never let the gun go uncleaned overnight with waterborne stuff in it.
I use Target Ultra lacquer in an Accuspray #10 gun.
Ed
Re: HVLP question
Thanks Ed!
Theresa
Re: HVLP question
Re: Thanks Ed!
Barryvabeach
>Theresa, remember the check the tip if you don't clean the gun after each use. I get a little build up on the tip sometimes between coats when spraying waterbase, and if you see some build up try to flick it off with a finger nail or it may impact the spray pattern.
Re: HVLP question
Re: Thanks Ed!
Theresa
>I learned that after a break between sprayings.
It was easy to take care of, as you described.
Thanks Barry!
Re: HVLP question
Spray tip
>Ditto the little buildup of crud right at the nozzle opening.
I've been spraying with Target USL for 5 years now. Early on I did have a buildup of dried lacquer inside the nozzle tip that eventually degraded the spray pattern. Now I remove the tip and check it from time to time but haven't seen a repeat of that situation.
Ed
