coopered vessel
coopered vessel
coopered vessel
R Payne
>So i was playing with some maple from a tree I had to take down. This is what I came up with. The banding is pallet strapping. It does have a bottom and is held together by the banding like tradational cooperage. It is almost water tight, a few dribbles from the bottom and one small leak between 2 staves.
Overall size is about 4.25 inches diameter at the top, 3.25 inches diameter at the bottom and 7 inches tall.
No finish yet.
ron
Re: coopered vessel
Neato
>That is curiously about the same shape and size as a pint beer glass. I could see having a set of those around when the guys come over for darts and cigars.
I'm guessing that you somehow riveted the bandings and then drove them onto the tapered vessel. Did you have to form them on a tapered mandrel first?
Ellis Walentine, Host
Re: coopered vessel
question
Bill Tindall, E.TN
>how do you make a hoop from the banding, i.e. how is it fastened together?
I am in awe of coopering. I fret for hours to make one compound miter joint, never mind many that eventually have to meet in a good joint. .
Re: coopered vessel
Thats pretty cool ! " Proof-of-concept " ?
steve mackay
Re: coopered vessel
Re: coopered vessel
R Payne
>A rather simple description of the procedure I use is thus. I cut the staves on the table saw using a quick jig to hold the angle from top to bottom and the blade set at 15 degrees (for 12 staves). I numbered and cleaned up the joints between staves with a hand plane until it looked like they fit (and got all but one pair right). I cut the bottom on a band saw and refined the fit with a hand plane until it looked like it fit right. I cut the groove the bottom sits in with a chisel I made last week (had a need for a chisel about 1/8 inch and didn't have that size on had, so off to the forge). I cut some pallet strapping for the bands and hammered one side on the anvil to make it slope about the same as the sides when brought to a circle. I punched a pair of holes in each end (making sure they lined up) and used some tacks for rivets to hold the bands together. I held the staves in place with tape until I got the banding on, which was hammered down (up?) tight with a small hammer and cold chisel. Sounds fairly simple, don't it?
Then I checked for water tightness. It didn't quite make it. One slight leak between two staves and some dribbling from the bottom. I guess I've spent around 20 hours thus far.
I got the idea from a book on making a coopered bucket. I don't know where the book is at the moment and built this from what I remembered from the book.
ron
Re: coopered vessel
and by my calculation
R Payne
>it should hold something between 1.5 to 1.75 pints
ron
Re: coopered vessel
Re: coopered vessel
Lee Schierer - McKean, PA
>As I recall from my reading and memory, the hoops should have been heated and then dropped onto the staves before being hammered in place. When the metal cools addition compressive force is applied to the staves by the shrinking metal.
Nice job though.
Lee
Re: coopered vessel
good size
Tom Sontag - St. Louis
>Right off the bat I am able to think of a liquid that is conveniently served in such portions.
I am not sure how you fit the bottom. I remember reading something about slightly crushing the fibers before fitting so that the liquid swells it closed. Does this sound familiar?
Re: coopered vessel
Re: coopered vessel
R Payne
>Heating the hoops sounds like an idea to try. I don't remember it from the book i've got. I'll have to find it someday, maybe before I try another.
To put the bottom in, I cut a groove in the bottom of each stave that is about 1/2 the thickness of the bottom and shaved the edge of the bottom with a plane until it fit.
I think if I left water (or liquid) in the cup, it would swell the wood and seal the leaks. But I don't intend to leave liquid in it. So I'll find some way to seal it.
ron
Re: coopered vessel
Re: coopered vessel
Kenneth
>I went to Frank Klaus's seminar once. He had a water tight box which he keeps his wet stones in. This probably isnt applicable here with all the angles, but he used a heavy gauge wire and hammered a dent along all the butt joints. Then he would plane away the wood until he was level with the dent. He only nailed the joints together. The wood swelled where he placed the dent, which acted like caulking for a water tight seal. It was really cool to see this box holding water held together with just a few nails.
