200+ woodworking book reviews
Way OT, Roofing for a beach house?
>My cousin has a beach house on TopSail Island. Its one of the flat top ones from back in the day. The house has a smooth tar roof on it, but the wrap around porch has tin.
When adding the porch,she cut back the perimeter of the older flat tar roof and installed a new drip edge or flashing. The metal was supposedly heavily galvanized and suitable for the ocean invirons. So was he tin on the porch. Not so. Both have failed in a few years. It also appears that the runoff from the tar roof is doubling the damage to the galvanized metal.
These are very low pitched roofs. The main roof is probably 4 inches in twleve feet and the porch is aobut 1 in 12.
Any suggestions for replacements? Any web sites with advanced info? I should know this stuff, but the beach invironment is out of my league.
Re: Way OT, Roofing for a beach house?
>Certainteed makes a two component roll roofing that works well on a low pitch. A self-stick membrane goes down on the deck and trailing edge of the drip edge, and a peel-and-stick chip coated roll goes over that. I used it on our vacation house successfully. Also, you might check if there's a vinyl drip edge for seaside use.
Clint
russastrid
>you need to use non corrosive metals such as copper or aluminum. you will have to find a metal shop to manufacture what you need. i'm a roofer from miami
Scott in Eastern Iowa
>How about EPDM rubber for the low slope roof ?
Install it glued straight to some treated 1/2 plywood and your good to go for at least a decade or three.
Thanks Clint, I'll check it out.
>Russ, soes aluminum hold up at the beach? This house is too close to the Altlantic and I thought salt spray ate up aluminum. Thanks.
Thanks Scott, have you used EPDM yourself?
steve mackay
>I've got a flat roof here in El Paso that WAS the typical hot tar roof. When it finally got patched "to much" a roofing dude sold me on this rubberized membrane stuff. Goes on in rolls with the gravely stuff already on it. I belive they DID torch it down during instilation. It looks like the stuff Mike Holmes uses on flat roofs. Its only been on five years now ( ten year warranty ) But I gotta tell ya' . . . it acts kinda like a swimming pool up there. Completely sealed across the roof. Of course our rain water never hangs around more than a couple hours and it ain't much but so far so good.
Re: Beware of dissimilar metals *LINK*
>I.E. use aluminum nails rather than zinc coated nails for the roof if you use aluminum flashing. Galvanic action between the two dissimilar metals is really what corrodes the aluminum.
See the link.
Aluminum Corrosion
Indeed I have Barry......
>......I have installed thousands of squares of Firestone, Mulehide, Carlisle and a few others over the 6+ yrs I worked for a roofing company.
The company and most importantly the installers knowledge of the whole system, all flashings and especially the corners are key in my opinion. Done wrong and the roof will fail prematurley.
I also have it on 2 low slope or dead flat roofs of my house I am currently in. No problems seen in 14 yrs....and counting !
Re:Is EPDM a DIY type product?
Kneale Brownson dreaming of snow in N. MI
It certainly can be Kneale.....
>......Ive got the advantage of professionally installing it, but a Borg like Menards sells a water soluable product (Mulehide I recall) that is easily do-able by anyone with the elbow grease to go get it done.
All you need is a threaded broom handle, a paint roller for the yellow glue and enough rubber to cover the area/seams/flashing height etc etc. Overlap on the seams is done by using their special cleaner or white gas (is acceptable as well) then a black glue is used to glue the seams together. Lap seal on the seams length to waterproof the edge and protect it, throw on your metal flashing, strip it in using a uncured peel n stick flashing, roll it in for 100% bonding and your done.
Jim in Burlington Ont.
Cheap Solution
>I'd primer it with the special primer. Then apply epoxy 2 part paint to them. Deadedn the noise and outlast you and me.
Re: It certainly can be Kneale.....
>Is there more info available on this?
What part of the product is water soluble?
The stripping it in part? Do you cut the strips yourself or buy them precut? How long?
What is the "black glue"?
Is there an installation manual I could get?
Re: Cheap Solution
>Jim, do you have specific brands?
