OT-Outside freeze proof water faucets
Howard Norman
>I have an outside freeze proof water faucet that has, over time, gone from a decent water flow to a very low water flow. Inside the basement where the pipe goes to this faucet is a tee with a drain valve. When I open this valve there is plenty of water pressure and flow. I don't have any idea how these water faucets are made and what, besides a rock in the faucet, could be restricting the water flow. Any ideas on how to address this problem? If it is important this water line and faucet are probable 8-9 years old.
Re: OT-Outside freeze proof water faucets
>There's a long stem between the actual valve and the spigot, with lots of room for a critter bug to homestead. Maybe that's the problem.
Clint
Howard Norman
>>There's a long stem between the actual valve and the spigot, with lots of room for a critter bug to homestead. Maybe that's the problem.<
If that was the problem wouldn't you think that the water pressure would force it out?
>Gee, I don't know.
Clint
Dale Lenz
Dale Lenz
>Since your not familiar with this type of a faucet, should use two wrenches to remove it, pipe and Crescent wrench, at least thats how I do it. Find a neighbor that has done this or a plumber and watch him/her. Shut off water supply, remove faucet, turn water back on for 15 seconds or so to flush out pipe. Inspect faucet stem, etc., reinstall faucet. Hopefully, you just have sediment between your drain value and outside faucet. Good luck
Howard Norman
>The faucet in question is one on a stem in the yard so I will have to dig down to where it is fastened to the pipe before I can remove it. One of my grandsons is coming up next weekend so it sounds like a job to do while he is here.
Fred Davis
>Howard ,
If your talking about a outside hydrant that is mounted on a pipe riser about 3 1/2 feet above the ground , then the dig down is about feet feet and the problem is probably related to clogging of the riser pipe or the unit on top of the riser pipe is shot.
The pipe doesn't freeze in the winter because there is a small hole at the bottom (down five feet} that drains the water from the riser when you shut it off after using it.
A freeze proof hose bib mounted on the side of the house in a box that extends into the house wall to keep it warm , is a whole different deal.
FredD
Howard Norman
>Fred, the dig down is about two feet or so here but I still don't relish doing the digging. I built this house so I am familiar with the original piping.
Fred Davis
>Howard ,
The hydrants here come made up in a five foot below grade
configuration, since we had one replaced not long ago , I remember how it looked and I don't think it could easily be shortened, but the length may be peculiar to this neck of the woods ( Kansas ) we go down 36 " to get below any possible problems with foundations heaving from frost.
FredD
Dale Lenz
Re: Same Same
Dale Lenz
>Pipe wrench on ground pipe, Crescent wrench on faucet nut, no diggy. May need "cheater" pipe on Crescent, keep ground pipe stationary or you will be digging. Remember to turn off water supply first.
Good luck
Howard Norman
>Fred, the lengths of the "stem" do vary. I recall when I bought mine years ago that the plumbing distributor had at least two lengths maybe three lengths in stock.
Dale, after I read your post and reposted I was wondering if I misunderstood and you were talking about removing the head of the faucet without digging. That sounds better but as you mention you certainly need to be sure that the stem is held tight or you will have to dig. Thanks for the clarification.
Re: hydrant drainage
Kneale Brownson dreaming of snow in N. MI
>I've installed several of these hydrants. It's important that the bottom drain hole gets a street elbow and piece of pipe (they're usually 1/4 inch) that has a good drain material around it. I always used a gallon pail of drainfield stone around the pipe with some resin paper of tar paper over it to prevent sand invasion of the stone. Without the street elbow, it's possible for sand to get into the drain, which is below the shutoff. It's also possible the sealing medium (just like the washer in any faucet) deteriorated enough that some scrubbed off and is blocking part of the flow. Either kind of blockage should be cleared by taking the head off the stem and turning the water pressure back on. You'll want to be certain the stem doesn't turn during head removal, so it would be best to have a two-person team doing the disassembly.
