Sort OT, but I need a good source for some good quality smooth operating pulleys. I am to the point that I need to use the space over the garage door, and I want to make the platforms move up and down. I am aware that this might not be the optimum solution, but anything right now will be better than cluttering up the shop floor.
>I have a 12V electric whinch I got from them a few years ago. I used it to pull cars and stuff on a 18' trailer. When I left WA I had it in the garage until the day I had to pull some bushes and it did a great job and saved my back and time. It was about $30.00 they do have 110V ones also that could pull a motor.
>Lot of places have the platform lift pulley systems. The rope lengths are alreay figured out and set up for you. The last one I saw looked like it was cheaper than buying all the components seperatly then doing all the figuring yourself. Just a thought.
>Rob, Many marinas have pulleys in the parts dept. that are top of the line since they are used in tough conditions at sea, mostly on sailboats. A couple good ones and some nice line should be an easy project. Phil
>AAny hardware store pulley will probably work as long as you pay attention to the load rating of the pulley. If you can find pulleys that are rated for breaking strength you're better off. Most of the time they'll have a SWL, Safe Working Load which is meaningless unless you know their safety factor. When I choose gear for rigging trees I want at least a 5:1 safety factor. Knowing that a pulley will break at 5k# means that I can put a 1k# load on it for a long time and not worry. For your application you could probably get by with some small pulleys. Especially since you're likely to have the load supported by a pulley on each corner, dividing the theoretical load by four.
the most efficient pulleys will have bearings for the axle. bushings are probably efficient enough though.
A good source of sailboat hardware is attached.
More important for you will be to have a system that is as short as possible to keep the shelf high. Using the stainless pulleys will give you a strong and compact setup.
Pay attention to the cord that you use too. A kernmantle cord from a marine supply or mountaineering shop will give you a rope that is strong but likely to not have much stretch like a three strand cord from the hardware store. I use some 5/16" cord that has a 5k# breaking strength in some applications where weight and compactness is an issue.
