>Man, my jointer really looks like the deck of an aircraft carrier now that I've stripped everything in the way to remove the old cutterhead. The new Byrd head should be here this coming week.
At least I have things cleaned and after installing the new head I can make sure everything is adjusted again. I was a little surprised at just how easy it was to remove the cutterhead too!
>David, that'a purtiful sight. Probably won't ever be that clean again! Good luck with the install, and be sure to let us know how much of a difference it makes!
>Greetings David. I installed the Byrd head in my Gee Tech(aka Sunhill) 8" jointer. I had one minor problem. I had to shim up the end with the belt pulley. Not a hard problem but it did require removing the head in order to get the flat washer type shims in place. It now cuts like a dream, ready to glue.
>David, please post on the assembly process. I have the same jointer and have been thinking about the conversion myself. It'd be nice to know in advance if there are any quirks involved.
>I've been working more figured woods as of late and although the original three-knife head has done pretty good, the Shelix head will take things to an even higher level. With the original head I still would get tear out. The biggest problem I had was with edge jointing tiger maple. Because of the soft and hard grain going back and forth on the edge, the cuts were never flat and smooth, making invisible edge glued joints impossible.
The Byrd Shelix head cuts figured woods so smooth it's ridiculous. I figure it's time to take advantage of this technology.
