Wood Filler Recommendation *LINK*
David Yoho
>For many years I've been using Famowood wood filler and liked it. Recently I was given several different samples of another brand and have been trying it out. I always like filling places in wood with wood itself, when possible. However, there are times this is not possible or easy. That's when I turn to a filler.
If you haven't tried it or weren't aware it existed, I recommend giving Timbermate a try. It's available from Woodworker's Supply and Woodcraft as well as a number of other sources listed on their Website. It comes in many wood colors and even has a neutral base that can be custom colored.
I love this stuff because it's water-based and is much easier to work with than the solvent based Famowood I'd been using. It dries hard, doesn't shrink, takes stain or dyes great, sands nice, cleans up easily, and can even be used as a pore filler. One other thing I like about it is even if it dries in the container it can be revived just by adding a little water. I've never been able to do that with a dried can of the Famowood.
Check out their Website link below if you're interested. I think you'll quickly become a fan of this fantastic wood filler from "Down Under" once you try it.
David - (going to the shop to throw out all those cans of Famowood I'll not be using again)
Timbermate Wood Filler
Re: Wood Filler Recommendation *LINK*
del schisler
>I have used the wood filler timber mate work's very well Here is a link
http://www.woodworker.com/cgi-bin/FULLPRES.exe?PARTNUM=139-877&search=Timber%20Mate
Re: Wood Filler Recommendation - Question *LINK*
North of the Border
>Famowood also has the water-based fillers but at cheaper prices. Would they be similar to the Timbermate?
Waterbased fillers
Bart Goldberg
Bart Goldberg
>FYI - if your famowood gets dry in the can - just pour in some acetone and it will be as good as new.
Bart
David Yoho
>Thanks, Bart. Yes, I have done that before and it works up to a point. If the stuff is hard as a rock and dried out from sitting too long, it never has come back when I've tried it.
David
I knew someone would ask this
David Yoho
>The answer is, I don't know because I never used the water-based version of Famowood. Now that I have found and used the Timbermate, there's no need for me to find out. Over the long haul I don't think the difference in cost will be something to concern myself about because it won't go bad like I've had happen many times with the solvent based filler.
David
How does it compare to Durham's Rock Hard?
>It seems to have the same features as Durham's, which I sometimes mix with white glue for a super-hard sticky filler. It's especially good for filling tack holes and dings in frames when reupholstering old furniture. I assume any of the water activaded powders would work, as well.
Clint
Re: How does it compare to Durham's Rock Hard?
Yonak
>Clint, I have used, and have been happy with the results of Durham, as well, but I like the idea of different colors which are offered by the Timbermate product. I'm going to give Timbermate a try.
Barry Gork
>Timbermate is a non-toxic water-based filler that does not contain any acrylic or latex. Every other filler that claims to be water based is actually Acrylic or latex based. Therefore:
-It is zero-waste. Just add water to reconstitute (until you add finish)
-Will not shrink, sink, crack or fall out
-Can be used as a Crack, grain and edge filler
-Accepts any finish
-Can be tinted with anything for custom colors
-Comes in 13 ready mixed colors
Thanks, Barry
David Yoho
>Thanks for weighing in about your product. I leave all the technical stuff to folks like you. All I know is a good friend, Charles Neil, gave me several containers to take home and try out. I told him if it did all the stuff he told me it would, I would switch from what I've been using for over 15 years in an instant. I used the Timbermate recently on a cedar chest restoration I did and it worked so well I'm absolutely sold. You've got a great product there and a new loyal customer!
Thanks for such a great product,
David
Re: Just add water to reconstitute
Yonak
>Re : "-It is zero-waste. Just add water to reconstitute (until you add finish)"
Barry, does this mean that if it is applied on a surface which is left unfinished it is susceptible to disintegration if subjected to water spills or steam (such as from a steam iron) ?
Re: Smart Tails hand cut dovetail jigs *LINK*
charlesneil
>barry must be away, so i will answer....yes unless its finished it will remain water soluable...if you are looking to fill something that will go unfinished and be in contact with water and steam..either an epoxy based or solvent based would be better...Timbermate's properties allow it to be so easily worked and dyed or stained..it has to remain in a soluable state to allow it to do so...its the reverse with epoxys and solvent and most waterbases..they form a hard film filler...which is difficult to color...Timbermate accepts dyes and stains as close to the natural wood as anything i have ever seen...but will require finished over..which is the typical use for a filler...hope this helped...
http://www.antiquesbuiltdaily.com/tips.htm
Yonak
>Thanks for the info, Charles. I never considered the after-application water solubility issue with the Durham product because if I let it dry too hard in the mixing container, the container is nearly impossible to clean. ..So I read the product information label for the Durham's and it seems identical to the properties of the Timbermate product. Timbermate sounds like a great alternative because of the variety of colors available.
Timbermate
>Yes
