OT #$%^@#$#@ computer ;-)
Dan Donaldson
>Here I am just really getting into a project this evening when my computer starts acting very flaky. It was right after some updates, so I thought that had something to do with it. Played around for a bit, then rebooted and nothing, first a blank white screen, then black screen. Hmmmm, it is a black screen, but the hard drive sounds like normal boot. I finally got an old analog cable and hooked the analog output of the video card to the monitor and guess what; I have some level of display, not good, but there. So, looks like bad video card. Bummer, but at least it looks like the monitor and computer are OK. Go get new video card and whee!, computer is alive again and not acting strange anymore. Only real problem is 2 hours lost ;-( (and a few bucks for the card;-))
Re: OT #$%^@#$#@ computer ;-)
Ain't troubleshooting fun!!!!
David Yoho
>Good going, Dan. Those kinds of things seem to happen when you can least afford them to. Some might say I'm sick but I just love troubleshooting computer hardware problems. I've got all kinds of spare parts here but haven't had any problems in a long time. Damn the luck!
David
Lee Grindinger
For you two hours
Lee Grindinger
>For me it would have been days or weeks and probably a new laptop...,
..., couldn't have happened to a more qualified guy.
Sorry for your troubles, Dan.
Lee
Larry Clinton At Frankfort (Central)., Indiana
>Been there done that - I have one system I moved out to store in the workshop. Just got tired of fighting it and built a new core two duo. Mine started locking up intermittently - sometimes ok for a day - other times an hour or two (or maybe lock up 3 ~ 4 times in 5 minutes). I had already replaced the Power supply and added additional cooling to the tower. It was a Win 98 operating system - I checked for virus, removed several unused programs, deleted several updates, cleaned the processor cooling fan, etc. I never did determine if it was software or a Mother board problem (running on-board video, audio and Lan) as it was so intermittent. As it was about 3 or 4 years old I just replaced it and saved it to see if I needed anything off the old hard drives.
Re: Hijack: Monitor hourglassing
Kneale Brownson dreaming of snow in N. MI
>While I was reloading paper into my printer, I heard a soft "pop", and when I turned back to my computer screen, the image had hourglassed. The monitor does not respond to the hourglass adjustment. Should I go monitor shopping?
I would
Dustmaker Mike
>Look for a good LCD monitor. Cost less to run then the standard CRT. Look for one that is VGA and DVI and you can replace your computer latter on not have to replace the monitor.
Sounds like it
Dan Donaldson
>Pun intended, Look out George ;-) If you heard something like that, it is an indication that something blew. It is not economical to fix things anymore, so I would say that a new one is in your near future.
Alexander Grigoriev
>If you mean that the cursor turned to hourglass, then the monitor is OK. If, though, the image have become extremely distorted geometrically, then yes, the CRT yokes are pooped out. Get a new LCD one.
Alexander Grigoriev
>I would guess instead that your video card just become loose in the PCI connector.
Dan Donaldson
>Tried that first. Reseated all of the cards and connectors. No change. The card sorta worked on analog conector and my monitor worked fine on another computer. New video card and all is well. Old card back in---dead video. The card is dead ;-)
cheap cards
>Fortunately, video cards are so cheap these days they are almost free.
When I set up my first dual-monitor system on NT for 3D graphics work, I had to use two cards at around $2000 each. Even a good dual card with analog/digital output is inexpensive now. (Once you go dual, you can't go back.)
Re: cheap cards
Dan Donaldson
>Yeah, the one I got has dual digital outputs and cost just over $100. I don't need the real high performance cards as I am not a gamer and don't do much of anything that really taxes the video. The one that I got is an nvidia 8600 with just 512 memory. I probably could have gotten it cheaper, but I didn't want to wait or chase around too much for it. I don't have dual monitors yet, but now that the card supports them, I may have to try it. ;-)
Re: cheap cards
>(I wrote this days ago and didn't send it because of my own computer problem - my UPS crapped out and I haven't bothered to fire up the computer until today!)
If you haven't tried duals, I urge you to. I've been preaching duals since the mid '90s and have many converts. :) Today's hardware and OSs make is SO inexpensive and easy.
The biggest expense these days is the monitors, although they are a lot cheaper as well. I use two 20" LCDs with the narrowest black bezels I could find. I run the card in the "one wide desktop" mode at 2560x1024 and have the task bar spread all the way over both monitors at the bottom. This allows room for several custom toolbars as well as the tray and the other stuff.
Using duals while composing messages for Woodcentral is great since you can display threads on one monitor while composing on the other. Image editing is simplified with both Photoshop and a full screen image browser visible at once. I'd hate to build web pages or write software without duals. Document and reference material. Excel and data files. Video and audio editing can spread timeline, control, and view windows over a large area. This list is endless.
