Tablesaw lubrication
Kevin Mac Luskie
>I bought a used Powermatic 66 a while ago, and although I haven't used it a lot up till now, I'm getting ready to start doing a lot of work with it. I was going over it, cleaning it up and checking adjustment on it, and the height and angle adjustments are harder to turn than I think they should be. I checked to make sure the locking screws were not tightened, and used an air compressor really well on the worm gears to blow out all the current sawdust. In the book it just says:
"If binding occurs, clean off all sawdust and pitch buildup and re-lubricate with a good nonhardening grease."
Does anyone have a recommendation on what kind of "nonhardening grease" to use? will regular axel grease work, or the blue marine grease I use in the buddy bearings of my jetski trailer? Is there something that attracts less saw dust?
Thanks for you help.
-Kevin
