Quick squaring of fence to blade
Ken Garlock, Collin County Texas
>Humm, do you square a cabinet saw fence to the blade or do you parallel it?? Oh well, you get the idea. :-)
Yesterday I discovered that my Incra fence was in need of adjustment. I didn't like the idea of getting out the A-line-it gauge and spending the next 30 minutes tapping this and that until it was parallel.
I looked around the shop and found a flat piece of 3/4" plywood with a straight edge. It was just the right size to both height and length to sit on edge in the miter slot. I moved the fence up to the plywood and yes the fence didn't touch everywhere.
I loosened the adjusting bolts on the fence, and then clamped the fence to the plywood. The next step was to move the fence/plywood up against the far side of the miter slot making sure the plywood touched all along the slot wall. The last step was to re-tighten the adjusting blots, and I was done. I checked both ends of the fence against the miter slot, using my Starrett combination square, and the ends were exactly equidistant, to the nearest 1/64.
Should/when I need to re-adjust the fence it should be a 3 minute job using the plywood miter slot technique.
Some people like to have the far end of the fence a couple thousandths back from parallel. Although I haven't tried it, it seems that a couple slips of paper between the the plywood and miter slot wall should give the desired results.
Recommendation, if your miter slot is not parallel to the blade, fix that first!!
Just thought I would pass this along....
Ken
Re: Quick squaring of fence to blade
This would be an excellent tip...
>...to archive with a photo or two in our articles department. Maybe we need another category of articles that are strictly short tips like this...along with some more hours in the day, I suppose... :-)
Thanks for posting your tip.
Re: This would be an excellent tip...
Kneale Brownson dreaming of snow in N. MI
>A tip section would be great, or at least a search feature that would go to accumulated tips in the archive or something.
Theresa K
>It would be helpful to have a tip board. I'm sure you'll get right on that Ellis.....in your spare time.
Great tip Ken! Thanks, from the mechanically challenged.
Howard Acheson
>That will work but it is not as accurate as you may think. Plywood is very variable in thickness these days
Here is something that is easy and as accurate as using a dial gauge.
Here is the low tech, low cost way to align a tablesaw that I learned maybe forty years ago and use to teach to my students.
Make 3/4 x 3/4 x 12" hardwood stick. Drill a hole somewhat centered in one end and insert a brass #8 x 1" round head fine thread machine screw about half way. UNPLUG THE SAW. Raise the blade completely up. Clamp this board in your miter gauge (if you determine that there is some slop in your slot to miter gauge, use a playing card to take up the slop) so the screw head just about touches the blade at the front. Now rotate the blade by hand and determine which tooth is the closest. Adjust the screw in or out until it just touches this tooth. Mark this tooth. Rotate the blade so the tooth is now at the back of the table and move the miter gauge/stick assembly to the back and see if it touches the marked tooth to the same extent. If it doesn't, adjust the trunnion (if a contractor saw) or the tabletop (if a cabinet saw) until it does.
For a contractor saw, first use a small c-clamp on the rear trunnion and cradle to keep the assembly from moving. Then loosen the two rear trunnion bolts and one front trunnion bolt. Slightly loosen the other front trunnion bolt and use a stick to tap the trunnion until the blade and screw lightly touch. The blade does not move directly around the center so you will need to repeatedly go back to the front of the blade, readjust the screw, and then again measure the back. Be sure to check after tightening the trunnion as the trunnion frequently moves when being tightened.
For cabinet saws, loosen the bolts that hold the tabletop and tap one corner until things come into alignment.
The same adjustment gauge can be used to set the fence parallel to the miter slot. Slide the miter gauge to the front of the table and move the fence over to the screw head and insert a playing card between the screw head and the fence just so you can move the card as it touches both the fence and the screw head. Now move the miter gauge to the back of the table and see if you have the same feel when you insert the card. I like my fence absolutely parallel--if you want to have a slight opening to the fence, you can easily estimate the opening by adding a thickness of paper to the card.
I always show my students with a dial gauge that their adjustments are within .001 - .002.
You can also use the same gauge to measure blade runout by using a $5.00 feeler gauge.
Finally, after you are satisfied with the above adjustments, check the position of the splitter to make sure it is exactly in line with the blade.
Bottom line, there is no need to spend more than the $0.05 for the brass screw.
Fred Davis
>What I use to adjust tolerances on the TS costs a little more then a brass screw , but once you have them, they are nearly indestructible and fool proof to use.
1. Get a machinist to furnish a machined steel bar 3/4 by 3/4 by about 16 -18 inches long that is a snug fit in the mitre slot.
2. Get a master saw blank which is a ten inch diameter disc with no teeth and very flat, that goes on the arbor in place of the saw blade. (Nordic Saw and Tool in Turlock ,Ca.) sells them.
2. It is very easy to place the bar in the mitre slot with the saw blank turned all the way up and riding a combination square on the bar , check the the front and back edge of the blank to see how close they match.
If you need to move the table saw top , only loosened three screws and let the fourth one serve as a pivot, much easier to adjust then having all four screws loose.
3. I use that steel bar to align the fence and the crosscut fence to the rip fence by placing it in the slot closest to the rip fence and .using a framing square against the bar to align the crosscut fence to the rip fence.
4. Lastly if your crosscut fence bar is a sloppy fit in the slot , use a center punch and place about four evenly spaced dimples along one or both edges of the bar, depending on how much slack you need to take up.
FredD
>Howard, you make some good points. I may have been lucky with my plywood selection. I used my combination square as a depth gauge. I locked the fence in place first. Then I put the square head in the miter slot and slid the blade up to the fence. I got the same reading at each end of the fence. Maybe I should save that plywood for future alignments. :-)
An even better solution could be a jointed and planed piece of hard wood used instead of the plywood.
As for squaring the table top to the blade. I set my top up one time about 3 years ago The several times I have checked it since, it was on the money with the blade.
Thanks for your comments and ideas,
Ken
wiki
Carlos Clarke
>How about a wiki?
Then we would be doing the work.
A follow up
>Well good people, this morning I did what I was trying to avoid in the beginning. :-(
I dug through the cabinet for measuring thingys and got out the A-Line_It. At the near end of the miter slot, after moving the fence closer in order to cause the a-line-it dial to go through 2+ revolutions, locked the fence, and set the a-line-it gauge to zero. I then slid the gauge to the far end of the slot, and the difference in reading was between 2 and 3 thousandths. Not too bad for a q&d approach.
Happy sawdust,
Ken
