How to make a concave depression? *LINK*
Tom
>Any thoughts on how to make a concave depression in a wood slab, sort of like in the photo at the link below? I've got one idea, but it involves an elaborate rig for a router.
click here for photo
Re: How to make a concave depression? *LINK*
Mike Jurnigan in Suffolk
>How about an inshave, travisher or if you want the power tool route a course disk sander?
Mike
Sue McLam in Orange, VT
>How about doing it on a lathe?
Lathe
>This is a really easy lathe project. It's also the only way you'll end up with a uniform hollow that matches the radius of the chopper -- assuming you take reasonable care in turning it.
I've been using an antique chopper for many years, and I find that it works fine in a medium or large salad bowl, too. The bowl keeps the chopped veggies from scattering all over the countertop.
Ellis Walentine, Host
>Assuming the piece you want to hollow is small and not the top of a table, I agree with using the lathe. If you are not a turner you might find someone to do it who lives near you or to whom you can ship the piece. Ask on the Turning forum here.
Where do you live?
radial arm saw
Grant in Iowa
>My first choice for the depression shown would be a lathe for simplicity, speed and flexibility in the radius of the cut.
However, I have made such depressions before with a Radial arm saw. Like cove cutting on a table saw, it seems dangerous but with diligence, clamps, and a steady hand, it works pretty good. Here's the basic idea of how I did it:
-With the saw OFF, experiment a bit with your saw: Raise the saw arm and tilt the head to about 45 degrees as a starting point. Lock the carriage on the arm and release the vertical axis lock JUST ENOUGH to rotate the head to see if the blade will leave an uncut area in the center. Tilt the head more if necessary to cut to the center.
-Clamp your stock to the table securely, lock every motion and turn on the saw and lower the blade into the stock about 1/8". Now, with one hand on the carriage and the other hand on the vertical axis lock, release that lock just enough so the head can rotate. Turn the head of the saw so you are not climb cutting, which should be clockwise. You will need to raise the blade slightly when you make one revolution in order to unwind your cord. It may make sense to start your cuts with the head "wound" clockwise.
-Once you have the center cut to the depth you want, you can widen the radius by changing the angle of the saw head tilt (while the sa is OFF!). the geometry and range of motion of your saw will dictate the range of cuts you can make.
-You will be limited in the radius of your cut to what you can create with your blade and by adjusting the tilt of the head. That said, a decent range of radiuses are possible with these two factors.You can also make neat donut shaped coves up to about 10" or so in diameter.
-As with any tool or operation, think it through and proceed cautiously. CLAMP EVERYTHING SECURELY! DON'T loosen the vertical axis lock more than necessary to allow the head to rotate, or the play in the head can cause a hazardous situation. DON'T remove the saw guard, and DO use the anti-kickback pawl when making a cut (This works, since you are not climb cutting). Of course, make light passes to keep it safe.
I know some will say that this is a dangerous approach, but I would submit that it is no more dangerous than making a cove cut on the table saw, or spinning a block of wood on a lathe without the tailstock. As always, let caution and comfort level be your guide, and DON'T do anything you don't feel safe doing.
FWIW,
Grant in Iowa
Tom
>I'm in Green Bay, no lathe or ras, unfortunately. We have a local woodworkers guild, I may approach one of them...
Agree With Your Bottom Line!
Scott Blundell
>David Marks did this for a table, using a router jig like you are probably envisioning, here is a link to the project.
Sculpted Maple Bowl-Table
Ken Garlock, Collin County Texas
>Hi Tom. Check David Marks website. On one of his DIY channel shows he made a table with a "bowl" in it using a router.
It involved making a fancy jib for the router to ride on.
Good Luck,
Ken
RobRing
>An alternative that I've seen - figure out the necessary radius and hang a router from the ceiling pendulum style. Depending on the necessary radius, you may have to construct an appropriately sized tripod from which to hang the router if your ceiling is too high.
Rob
