ADVERTISE HERE - FREE TRIAL
Latest project
Latest project
Latest project
>Finally completed this piece for my 6 year old granddaughter after many months of fits and starts. The basic design is a copy of a commercial piece, advertised as created by Wendell Castle. Overall dimensions are 33w x 22d x 36h. The drawer box is 3/4 baltic birch, and the base is made of SYP stair tread material. I made the pulls from glass rod and brass tube and rod; the mounts are lacquered. The butterfly pic is one I took and had printed on canvas; there are different ones on the other side and finished back. The lettering is laser cut 1/8 acrylic with the same lacquer as the pulls. The finish is flat latex/acrylic wall paint topped with clear alkyd lacquer. Comments welcome.
Clint
Re: Latest project
Re: Latest project
Ron Jones
>That really looks nice Clint! I'm sure your grand daughter will cherish this. The pulls are outstanding.
Re: Latest project
paint
Bill Tindall, E.TN
>I like the effect of the coated paint. I shall have to try it.
Re: Latest project
Re: paint
>I applied it with a foam roller, thinking that it would produce a more uniform film than brushed, and not show any lap marks. That it did, but it also created a suede effect that I knocked down, but didn't eliminate, with 220 dry wall screen. The lacquer softens it more, but it's still there. I'll tell the customer that it's the latest fashion. Next time, I'll go back to a brush, or roller and brush.
Clint
Re: Latest project
Dale Lenz
Re: paint
Dale Lenz
>>>>Next time, I'll go back to a brush, or roller and brush.<<<<
Why not spray the paint on? Never have sprayed latex, not a good idea?
Excellent looking piece, BTW.
Re: Latest project
Re: paint
>I would only spray latex with an airless system. I think it's much too heavy to either siphon or gravity feed through a gun, and with a pressure pot, the needle and tip would be different than for lacquer.
Clint
Re: Latest project
Re: paint
Joseph Mulherin, Sr
>Guys, you CAN spray latex with the ordinary spray gun by doing this:
take one gallon of latex, add one quart of water and stir to a fully uniform thickness. Add paint to your one quart spray gun and set the pressure on your compressor to at most 35 lbs. While spraying you will have to clean the nozzle a few times with your gloved hand.
I have done my entire house about 4 times using this method and it does work very nicely.
Re: Latest project
Pressure or syphon feed?
Re: Latest project
Re: Pressure or syphon feed?
Joseph Mulherin, Sr
>syphon
