Gum/Pitch pockets in cherry questions....
>I'm making a chair out of cherry.
Getting some gum pockets in the stretcher and leg wood. Any good inexpensive ways of detecting them?
Currently, I've been filling them with a 2 part epoxy and just leaving the dark area show. I could make up a filler with malachite or key shavings, but I'm not sure if I want to highlight the pockets that much. I also would prefer to err on the side of more strength (they are stretchers and legs). Anyone have any other preferred fillers that are reasonably strong?
Re: Gum/Pitch pockets in cherry questions....
Keith Newton, LR, Arkansas------WebKitFormBoundary
>I initially thought you were just talking about little specks, but it sounds like maybe something larger. I would just avoid using it all together. How much wood will you be wasting to cut new stretchers? That is no place to be wasting time and chancing strength on defects.
Dave Bair, Eaton Rapids, MI
>Pack the pocket with cherry plane shavings and yellow glue and clamp with heavy pressure 'till dry. The compacted shavings are as close to the original wood as I've ever seen and very hard to detect once finished.
>The pockets are a bit small for that - ~1/8" x ~1/4" at the most. I might try using dust though.
Re: Is 1/8" x 1/4" small?
>For the larger ones (greater than 1/4"), I usually try to find another piece. For smaller ones, I've been filling them. I just hate to be doing a bulb or a curve and cut into a pocket all of a sudden.
