Way OT - Computer printer network question
John T
>Cable internet comes into the house, to the cable modem, then into a wireless router. My computer (the "Main" computer, XP Home) isn't wireless capable, but is plugged into the router by a LAN cable.
SWBO's computer (XP Pro) is wireless, and communicates just fine with the router. Ditto with her wireless laptop (XP Pro).
We had an old HP printer that was somehow able to print from all 3 computers, so long as my "Main" computer was on - this computer was hooked to the printer via printer cable.
I bought a Brother 5280, wireless (supposedly), but I can't seem to figure out how to connect to the thing wirelessly. It will print from the "Main" computer, if it's wired via printer cable, but nothing I can do will make the other computers able to "see" the printer.
It used to work with the HP printer, but I'd like to have all of the computers able to use the printer without one of them being on all the time....
Please email me off board (jgtrupe@yahoo.com) if you can help.
Help me, Mr. Wizard!!
-John-
Re: Way OT - Computer printer network question
Apples and oranges
>Pretty common difficulty..... printer sharing. Let me see if I can explain quickly.
The old HP printer was a direct connect printer. It didn't really exist on the network, but instead it was connected directly to the PC via a USB or Parallel cable. Other computers couldn't access the printer directly, but instead sent their print requests to the computer (whcih was "sharing" the printer), which in turn sent them to the printer. All other computers on the network could only print to the print if the main computer was running because it was printing "through" the main computer.
Each of the computers is a "device" on the network, connected by the network switch built into the router. The printer, however, was not really a network device.
This new Brother printer, still has the ability to be a direct connect printer, via a USB or Parallel cable to the main computer. However, it has the extra ability to become a network device by itself on the network. The wireless feature somtimes just complicates understanding. Just think of the printer as having the ability to be a network device, either via a network cable or a wireless network connection.
When a printer is a "shared" printer directly conencted to a PC, then Windows automatically does what it needs to conenct to it. However, if it's a actual network device, then Windows needs to connect to it differently (via IP address). This is usually best accomplished using the software supplied by the pritner manufacturer. Not only will it provide the "drivers" necessary to print to the printer, but should also configure the PC to be able to find it on the network, since Windows by itslef might not be able to.
I'm not going to go into details of the Brother software. I try to deal with only HP printers and don't like other brands.
Happy Woodworking!
Summary
>Your old printer was a "shared" printer, only accessible through a main computer that had to be turned on.
This new printer has the ability to be a "shared" printer, liek the old one, but it also has the ability to be an independant network device.
To make it work as an independant network device, you kinda have to forget everything you used to know about the printer on the network, and rely on the printer's software to do it. And the printe rsoftware will (usually) need to be installed on each comptuer individually.
Hope that explains it better.
Happy Woodworking!
Quick start guide?
Chuck W
>I was just looking on the Brother website and they recommend to use the quick start guide to set up the printer. You need to install some software then follow the guide to make it work.
Something else
>You should have a WiFi security password or passcode on your wireless network. So in order for a device like your wife's laptop, to connect to the router wirelessly, you must supply the password.
You must supply that password to the printer too, so that the printer can connect to the wireless router. The printer software utility will likely help you connect to the printer (via a cable) in order to program the printer with the WiFi password so that the printer can connect to the router wirelessly.
Happy Woodworking!
Thanks Mark!
John T
>Thanks for the replies, Mark -
This kind of explains some of what I couldn't figure out. I've been trying the setup software that came with the printer, but still not getting where I need to go. I was kind of hoping there was a setting in Windows that I was forgetting about. I'll dink around with it more tonight....
Thanks again for taking the time to reply.
-JOhn-
Brother answers their phone
Curt Harms
>I have a networked(wired) Brother MFD. I had an issue with it and called the Brother support number. Not only did I get thru pretty quickly, the person I was talking to was in Tennessee, not Taiwan or India or.... I've had good luck printing & scanning with this device from Win2000 & XP Pro. It connects to the router via an ethernet cable, the newer version will connect wirelessly if desired.
HTH
Curt
Alex Grigoriev
>Go to printer's Properties (in Control Panel) and enable sharing for it.
Thanks Curt
John T
>Thanks for the reply, Curt -
I've been messing with it again tonight, and still can't get the printer to talk to the wireless router, or the other computers.
The installation disk isn't getting it done, for some reason.
I can print to it if I hook up a cable directly, but the wireless functions aren't there.
I've even disabled the firewalls and other protections on the router, and all the computers, then run the installation program, and still get no love.
How did we ever waste this much time in the days before computers???
Thanks again for the reply.
-John-
Thanks Alex
John T
>I tried that, and everything else I can think of in Windows, with the router settings, and on the printer itself, and still the installation software can't see the printer.
Prints OK if I hook up via printer cable, but that's not the idea....
Will call Brother directly when I have a chance during the day and see if they can walk me through it. Probably missing a firewall setting or something.
Thanks again.
-John-
Ethernet cable - chicken or the egg
>If the printer has an Ethernet (network) cable jack (I haven't seen a WiFi one that didn't) then plug it into the router. Assuming the router is a DHCP server (issues IP addresses) the pritner will pick up a new IP address as it should. Then the software will do a network scan to find it's IP address and connect to it. Once you know it's IP adderss (on the ethernet port) you can either use the software to talk to the printer or use Internet Explorer to talk to the printer.
The key is that the printer has to be on the network first, and using the ethernet cable is much simpler and more automatic. Once it's one the network (hardwired) you talk to it (via it's configuration utility or web page) and then from there you can adjsut and configure it's WiFi settings. Then you can connect it via the WiFi. Once it's connected via WiFi, then you can unplug the network cable and it will remain connected to the network wirelessly.
I setup these things all the time (although there are too many makes/models to have seen them all), and the methods and utilities vary even with products from the same manufacturer. But regardless of the details, the methods are pretty much similar.
Happy Woodworking!
Which cable?
>"...Prints OK if I hook up via printer cable, but that's not the idea...."
I'm assuming that in this case, you mean a direct connection USB or Parallel cable.
You probably need to connect the printer to the network via a ethernet network cable first, establish a connection from your PC to the printer over the network (not the USB or parallel cable). Then once you are talking to it's configuration page, that is where you likely will have the chance to program the WiFi passcode into the printer so that it can then connect to the wireless network.
See my other response higher up for more info.
Happy Woodworking!
