OT....need suggestions for repair of siding
Roger Lance in GR, Michigan
>I've decided to get an early start on painting the outside of the house this year and have begun the task except this time I've got a new problem...seems some woodpeckers have made some holes about the size of a quarter or so in the siding which is the old hardboard type (compressed cellulose and glue)...this siding is in otherwise good shape for 35 years of wear and weather...these holes are concentrated in a few spots and I'd rather fill these holes as opposed to replacing the boards with cement based siding (the old hardboard siding is no longer available)...so I'm seeking suggestions on what products I might use to make these repairs...I'm thinking it should be flexible initially to get pressed into the holes and then harden and maybe be sandable to a feathered flat and then take paint well and be impervious to water and the elements...what say you boys??
Re: OT....need suggestions for repair of siding
Kneale Brownson dreaming of snow in N. MI
>I've used a paintable caulk to fill woodpecker holes. I press it in with a putty knife, let it cure, scrape off any "spillover", prime and paint.
Bondo
Dustmaker Mike
>I think I would use Bondo. It paints nice and holds up great to weather.
Re: Bondo
Gene Gauss
>Yep, Bondo. I've used it to repair a couple of window frames that had some rot, and it's held up for years. It shrinks a bit when it sets, so build it up with several applications and sand it out smooth. Any auto parts store will have it.
Re: Bondo
Fred Davis
>Bondo will do it , if you have never used it before , a tip to ease sanding is to use a "cheese grater" also called a Stanley Surform plane to cut the Bondo before it gets cured, while it is still green and before it gets rockhard.
FredD
Re: Bondo
Alan in Little Washington (NC)
>Yup, Bondo. Works great on HardiPlank also.
Jim Dillon
>Roger,
I've gone through nearly a 1 gallon container of Bondo for rotten window repair, woodpecker holes, and bird bath repair. Works great. I got my Bondo at the local Borg. I can't say for certain, but the Bondo purchased from the auto parts store may have other ingredients that may not be necessary for home repair. There was a good thread on this topic a year or so ago and one poster IIRC said that people who repair boats would not touch the stuff because it absorbs moisture. I may be fuzzy on the details, but so far, I have not had any problems with the Bondo labeled for "home use". Give it a try.
Jim
Rich in Mn
>There is usually a reason (bugs) that woodpeckers make holes in siding. Make sure you get ride of the reason or they will make more holes.
George Koch
>After repairing woodpecker holes with bondo on one side of my cedar sided home a couple years in a row, the last time, I hung a plastic owl out there and they haven't been back since.
r payne
>I am aware of 3 reasons a woodpecker will hammer on something. One is a bug infestation as mentioned. The other 2 are "knocking" either to establish a territory or attract a mate. You should make sure that bugs aren't the problem. If not then there are a few thing you can hang up to scare the peckers off.
ron
>Thanks for your responses...the woodpeckers have left the house alone for the past year or so even though I still see and hear them around the house...there is no sign of an insect problem but I will look into treating the area to be sure...I will check into the bondo and give that a try...I wasn't a car guy so this will be a first use...I felt like that poor sap in the cartoons when I'd go outside to observe a woodpecker in the act, it would immediately fly off...so there was no shooting the little culprets...if they return, I'll check for bugs and hang an owl/hawk...thanks again.
