Not an electrician but ...
Forrest Addy
>The motor name plate lists the rated voltage and full load amps and from that rules have been extablished for sizing the conductors and circuit protection. You local electrical code has the final say on these matters but usually the National Electrical Code provides the rules in situations where local code does not address electrical requirements. You need to refer to both because different authorities often post higher minimum standards than the NEC provides. You may need GFI on the pump circuit in some districts but not in others for example.
This does not address your question which I think originated from the actual anicipated current demand of your sewage pump. That's difficult to anticipate because centrifugal pumps have several non-linear characteristics affecting demand. Generally, an induction motor draws at idle about 40% of the full load amps. Actual load on the pump depenends not only on the total lead pumps but the restriction of the connected piping. Under some conditions, a centrifugal pump may edge toward overload if the head is less than max but the overall restriction is small.
If you can size the circuit feedng the pump according to the direcions listed in the information provided by manufacturer you won't go wrong. One thing: is this pump to serve an actual sewage application where soft solids and toilet paper are present in the effluent? If so your pump has to be designed specifically for this service to meet code. A grey water or common sump pump may clog.
I'm not an electrician but I have residential and industrial knowledge and experience in electrical matters. I strongly advise an electrican be consulted to comment on the application and specify deails of conductors, routing, and circuit protection.
